well ive polished the pipe that goes to my throttle body.
and removed the seams that are on the pipe so it looks perfect. spent ages with the orbital sander and 800 grit sandpaper, my fingers are allmost falling off. then i buffed it.
anyhow now im goin to sand my cam covers.
heres a pic of the pipe
https://www.sau.com.au/forums/topic/14273-polishing-engine-bay/
you have to do the plenum now!! :D looks awesome man!
i dont know if i would have the patience...
how long did it take for each bit???
i just painted my pipes and the rocker cover... want to polish the cam covers like u have and then the plenum.
Very tidy!
Im thinking of doing the same (but by hand at this stage - might live to regret taking it apart!).
I have same rocker oil sweat seeping between the cam cover and the rest of the block - did you put a new gasket in, use the existing one, or use some kind a gasket-in-a-tube stuff?
Did you need to change the oil to do this or just be very careful while having the cover off?
Cheers :(
RGS
Its hard work but its worth it for the results. Mine looks pretty much the same as MotoX's now.. next step intake plenum.. Lot of work in that one.
I just use the existing gasket as it seemed to still be in good condition. All back together and been for a few long drives and working fine. No sign of leakage.
Oil all sinks to the bottom of the engine, meaning its all bare. The only thing you really have to watch for carefully is no dirt or sanding particles getting into the cam area while the covers are off. Recommend you do the actual polishing a few metres from the car.
well guess what i did yesterday and part of thursday night.
i busted my hands apart sanding this god dam ****ing plenum.
i dont recoment tyreing to do your plenum. its jsut too hard.
its too hard to get off, unless u take the inlet pipes off as well, which u have to refill your coolant. or u can do what i did and spent 2hrs undoing these 5 bolts.
but this is what it now looks like. and my hands still hurt.
i think thats why i had trouble drifting last night hehehe, or it was jsut the rain and the 6L of diesel on the road. dam sliprey roads
why so hard to get the bolts off?? You had acccess to the right tools?
you have to take the left rocker cover off to get properly to the bolts on the right of the plenum as well correct?? Was looking at how it might be done... i knew it wouldn't be easy.
From the result its worth it mate :(
predator666:thanks predator, yeah i took the left rocker cover off, still hard to get too, i used a ring spanner, the plate on the plenum that attached to the Throttle body slices ya knuckles apart.
DJ_L3ThAL: yes theres is a ruber/steel gasket, its easy to take in/out and it is reusable.
jsut re tentioned all ym belts, and i had a boost leak, seems all fixed now.
I used 240 grit sand paper on the orbital sander, then i rub it back till its baby smooth with 800.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
