well ive polished the pipe that goes to my throttle body.
and removed the seams that are on the pipe so it looks perfect. spent ages with the orbital sander and 800 grit sandpaper, my fingers are allmost falling off. then i buffed it.
anyhow now im goin to sand my cam covers.
heres a pic of the pipe
https://www.sau.com.au/forums/topic/14273-polishing-engine-bay/
you have to do the plenum now!! :D looks awesome man!
i dont know if i would have the patience...
how long did it take for each bit???
i just painted my pipes and the rocker cover... want to polish the cam covers like u have and then the plenum.
Very tidy!
Im thinking of doing the same (but by hand at this stage - might live to regret taking it apart!).
I have same rocker oil sweat seeping between the cam cover and the rest of the block - did you put a new gasket in, use the existing one, or use some kind a gasket-in-a-tube stuff?
Did you need to change the oil to do this or just be very careful while having the cover off?
Cheers :(
RGS
Its hard work but its worth it for the results. Mine looks pretty much the same as MotoX's now.. next step intake plenum.. Lot of work in that one.
I just use the existing gasket as it seemed to still be in good condition. All back together and been for a few long drives and working fine. No sign of leakage.
Oil all sinks to the bottom of the engine, meaning its all bare. The only thing you really have to watch for carefully is no dirt or sanding particles getting into the cam area while the covers are off. Recommend you do the actual polishing a few metres from the car.
well guess what i did yesterday and part of thursday night.
i busted my hands apart sanding this god dam ****ing plenum.
i dont recoment tyreing to do your plenum. its jsut too hard.
its too hard to get off, unless u take the inlet pipes off as well, which u have to refill your coolant. or u can do what i did and spent 2hrs undoing these 5 bolts.
but this is what it now looks like. and my hands still hurt.
i think thats why i had trouble drifting last night hehehe, or it was jsut the rain and the 6L of diesel on the road. dam sliprey roads
why so hard to get the bolts off?? You had acccess to the right tools?
you have to take the left rocker cover off to get properly to the bolts on the right of the plenum as well correct?? Was looking at how it might be done... i knew it wouldn't be easy.
From the result its worth it mate :(
predator666:thanks predator, yeah i took the left rocker cover off, still hard to get too, i used a ring spanner, the plate on the plenum that attached to the Throttle body slices ya knuckles apart.
DJ_L3ThAL: yes theres is a ruber/steel gasket, its easy to take in/out and it is reusable.
jsut re tentioned all ym belts, and i had a boost leak, seems all fixed now.
I used 240 grit sand paper on the orbital sander, then i rub it back till its baby smooth with 800.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
