  • Replies 47
i got in trouble for having one mounted on my dash apparently u arent allowed stuff on your dash
there goes my soft toy collection :)
yeah because it blocks your view apparently
i would have just span some shit like "yeah but so is the rear view mirror...and the steering wheel...and the frame of the car... but people can move their heads you know to see around it."
on the other hand its probably best not to say that.
Edited by Bloodlust
It is apparently an obstruction or distraction for the driver, but you can have the unit mounted on the windscreen if you turn the display off. The current BEL range you can do this and still get the audible/voice alerts so the display really isn't needed anyway.
If the cop wants to say it's a visible obstruction then just move it to the drivers side corner of your dash and tell them that it isn't taking up anymore room there than their in-car K band radar antenna... if they are happy to remove theirs then you will do the same!
  • 4 weeks later...
i recently bought an el-cheapo whistler 1732 detector...my 2 cents
1. driving on highway...beeped twice (possibly from handheld) coz about 1km after..2 cars were pulled over by cops for speeding -dectector was on city mode with all bands turned on
2. detector was on quiet mode...beeped once passing a petrol station...no beeps after ...300yards on..there was a tripod mounted radar....made a u turn...and drove past the radar again ....detector did not give off a signal...u turn again...drove straight past the radar...no signal..but the guy was fiddling with the radar so it prolly wasnt turned on
2 hours later...drove past the radar again...still just the single beep from the petrol station...turned and drove past again...cop was dismantling the radar..so couldnt test further
anyone know what band the tripod mounted radar uses?
Multanova's are Ka band and are supposably the hardest to detect since there so low power. IIRC there on the higher limit or just out of Ka band because they drift so much (and hence aren't that accurate...), the wideband detectors do really well against them.
I bought a shit cobra detector off ebay and it doesn't go off until your right next to the thing... its probably just your detector being shit. The cheap ones are really a waste of money for use with multanova's.
Dan, lasers are only used as handhelds. The tripod thingo's (multanova's) are all radar still. I'm pretty sure those camera's they stick in wheely bins are radar aswell, lidar makes it harder to get all the lanes at once.
GODTHRILA, I need to come see you to do some testing :happy:
Do you have a lidar gun at your work? I have a 'concept' I'm keen to test :P
GODTHRILA, I need to come see you to do some testing ;)
Do you have a lidar gun at your work? I have a 'concept' I'm keen to test ;)
The handheld lasers can be mounted to a tripod for further accuracy... they set these up a lot near Mandurah so I am told.
fr0st, just come and see me, we can test your "concept" with our laser
The multinovas are set up and operated by people who are outsourced. They are not official police officers ad have no standing to detain people. All they can do is call for the police.
I just thought they were trained/qualified cops... my bad ;)
I've never seen a tripod being used before in Perth. As far as I'm aware the max distance they can use lasers at is 400m and still have it hold up in court. Probably wouldn't need a tripod for that, but I haven't used a laser gun before so I can't really comment.
Can you pm/post you business address? It only lists a PO box on your website
Cheers ;)
GODTHRILA, what would you recommend as a good value for money (cheaper ;)) radar detector?
sorry to jack the thread.... but keep an eye out in the for sale section... I might be sorting out something for the forums sooner than you can say "two all beef paties special sauce lettuce cheese pickles onions on a sesame seed bun"
Cheers ;)
I've never seen an eskimo before so they cant exist
or maybe I havent been around enough :)
ok my bad...it was an outsourced person (i.e: no copper uniform...and sitting in a white 4x4....think it is the multinova's ...laser/radar....damned if i knew...bloody thing looked like a friggin missile launcer waiting to blow up any hoon
so what do u guys recommend for detecting multinova's? ...or do they generally trigger off the detector only if its targeted at ya?
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
