Heya all, dunno how you guys feel about "Hi I'm a newbie" posts so mods feel free to lock/delete the thread if it isn't the done thing. :D
I just picked up an R32 GTSt on thursday (got it from QLD and drove it straght back to newcastle) and have to say I'm pretty happy with it!
I spent a fair bit of time on PF mostly ripping on skylines in order to stir up Kabab and Southo :P but I'm pretty happy to have gone to the "dark Side" :D
Can anyone tell me how to tell ifn the 4WS is operating? There is no visual indication of it at parking speeds, I dont know enough about it on these cars.
Secoh
https://www.sau.com.au/forums/topic/14286-new-to-the-r32/
  • Replies 40
Secoh the best way i found to experence it is find a long swepping 80km/h turn try to keep the stearing wheel in a locked postion around the corner and you should feel the back of the car sligthly comming around to reduce any understeer.
Now if you want to get rid of the hicas;
In the boot under the parcel tray on the drivers side there is a computer with 2 sets of cables running into it.
Unplug the smaller set of cables MAKE SURE YOU LEAVE THE OTHER SET PLUGGED IN.
Say good bye to HICAS :D
Welcome to the dark side..
https://www.sau.com.au/forums/topic/14286-new-to-the-r32/#findComment-288713
Originally posted by Secoh
Heya all, dunno how you guys feel about "Hi I'm a newbie" posts so mods feel free to lock/delete the thread if it isn't the done thing. :(
hehehe Secoh we're pretty relaxed around here, just post all off topic shit in the wasteland and you'll be right.
Congrats on the r32 purchase btw :D
https://www.sau.com.au/forums/topic/14286-new-to-the-r32/#findComment-288754
Heya all, dunno how you guys feel about "Hi I'm a newbie" posts so mods feel free to lock/delete the thread if it isn't the done thing. :)
the mods are nazi's! and must see pics of all newbies skyline's..
nah. but pics would be nice, any mods?
also congrates on the new car.
https://www.sau.com.au/forums/topic/14286-new-to-the-r32/#findComment-291380
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
