I am wondering if nismo brought out 555cc injectors in almost a burgundy red colour
from pictures ive googled they look identical to the 740cc
I also thought the part number may be listed on the actual injector instead. the only text i can see is 'made in japan'. Any ideas how i can tell if they are fake?
Cheers!
https://www.sau.com.au/forums/topic/142876-red-555cc-nismo-injectors/
pics?
who did you buy them off?
Do you want to see any particular angles?
I bought them from a registered business in perth. Workshops i have spoken to recommend them as being honest.
He got them from a guy who sells performance parts to a number of workshops in the area.
Nismo 555cc injectors for r33 are yellow, 740cc are red.
Thats what i thought but he swears black and blue they are 555cc
The only thing im really worried about is that if they are not genuine, they might be a lower quality and fail on me
Did you get them new?
Where they in a box and sealed in a plastic bag?
Do they have any markings or manufacturers details?
Do not put them on until you know what they are for sure...your tuner can do a flow test on them to see what
they are.
Hope I have been of some help.
Cheers :yes:
they are.
Cheers :yes:
good advice althou when i bought my nismo 740cc they didnt come sealed in plastics they where just in a nismo box.
You better get them flow tested because you need to know what they are rated or else your going to have a hard time putting in the injector duty cycle value in an aftermarket ecu
This is a comparison between nismo injectors and my injectors. they look quiet different to me. infact ive found some on ebay that look the same selling at about $330 US (set of 4)
http://cgi.ebay.com/ebaymotors/740cc-Deats...7QQcmdZViewItem
Where did you get the injectors from?
The deatschwerks ones are hiflow injectors. I just installed deatschwerks injectors into my R33. They are stamped with a number on the injector plug which corresponds to the flow report. IF they don't have the number stamped on them, then they are most like not Deatschwerks
you sure there not those venom injectors getting around.
does it say JECS anywhere?
It may be possible that there simpy an older model NISMO injector, I wouldnt get too worried if they dont look exactly like the latest edition. A few people have confirmed them as being 700's so they most likely are.
Edited by James_03
yes it does say JECS, does that mean their venom?
there are actually numbers on the top
6E555707
A46-00
Are venom any good? (just out of interest)
6E555707
A46-00
Yep they are JECS 550cc I have exactly the same ones that got delivered yesterday :) They are not NISMO but they are good injectors.
What would be an average price for a set of 6? are they as expensive as the nismo ones?
I got them off another forum member still in their plastic for about $100 each. I was happy with that seeing as other ~550cc injectors are around $140+ each.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
