hey...
I had my GTS r32 dynoed about 1 1/2 years ago, mods were a 2 1/4inch exhaust and a k&n pod (which is actually on an adapter thats about 1 -2mm smaller that the afm opening) with no cold air induction..
Heres my dyno chart, i had lost it for quite some time but found it the other day and started to have a really good look at it.
rb20de dyno
As you can probably tell by the speed it would have been done in 3rd gear which isnt right i know but...
I noticed that my peak power was reached at about 5700-5800rpm, the power then seems to drop off significantly after this, thats what i find quite odd. This engine stock should be producing its peak power at 6100or something like that but by the time iv reached those revs the powers already dropping off quite quickly.
Is there anything that anyone can suggest that could be going wrong there to make the engine stop producing power where it does?? Is it possible that the dyno reading was setup wrong therefore meaning that the speed shown on the graph does not match that of the revs that i have plotted on there?.
Its hard to say for sure but when the car was new to me it used to come on power at about 5000rpm and pretty much maintain that pull right through to about 6500 and only slightly drop off by the time i would shift at 7000rpm. Now the car seems to all ova sudden go quite hard as soon as i huit about 5grand but die off again quite drammatically after this point.
In a way im kind of hopeing theres something only simple wrong so meaning that when fixed the motor should continue to make more power right up untill atleast where it makes it stock from the factory.Im wondering if it is my pod setup though thats sent things a bit wierd.. i should really do it properly and mount it down in the front bar and use the right adapter for it..i know people that have gained about 2.5 to 3kw's at the wheels by doing this..( a neck breaking difference i know, LOL :yes: )
Any input appreciated... cheers!
have your AFRs cleaned up, it won't entirely solve your problem - but it is a little over the shop. do you have an SAFC, ecu, chip or anything?
as to your power issue, the graph looks fine to me - but you've had history with the car, so just start troubleshooting. have a fiddle with your pod filter, service the car, look into timing advance/retard, etc.
that said - the dyno always feels/drives differently to when your actually on the street, so don't take it as gospel. does it "feel" slower to you?
Well the cars just clocked over 149 000 km's and it would appear to be the factory standard cat going by what it looked like when i got the got. i doubt the jap owner would hav changed it in the 90 000kms he they had the car for.. You think my cat could be killing off some of the power?
nah its the stock ecu etc... iv been told of someone that can do a remap for really cheap for me that might help things along a bit..
i just spent a few hours re-drilling and cleaning up my pod adapter and I THINK the car seems to be pulling a bit harder up top, but id say the biggest thing that has changed is the engine seems to respond a bit better now iv mucked around with it a bit.
Cubes, so you think its normal that my peak power is coming on before what nissan quote for my motor and already start dropping off hardcore by time it reaches that point, i would have thought that having a pod and exhaust would have pushed it up further if anything..
cheers
The RPM data on the bottom of the sheet seems to jump around everywhere. Speed versus RPM will remain constant in one gear. From what I can make out, your RPM jumps from as little as 600rpm per 15km/h increase to 1000rpm per 15km/h increase in speed. This can not happen. Until you can find out your actual RPM I wouldn't bother trying to work out anything, it looks like a normal dynograph to me.
Fixxxer
Hey mate,
I've got an r-32 GTS too, I can't really help you with the graph business caus I don't have a great deal of knowledge when it comes to dyno's, but I noticed you said about mounting the Pod in your front bar, how do you do that without cutting into your chassis?
I have had a good look and I can't seem to find any route to cold air?
Sorry for the off topic ness lol
your graph doesn't look that bad for a stock ecu. i'd say that is pretty close to what it should make.
when i had a SSS pulsar (natro sr20) i put it on the dyno and got a similar readout. graph was a little bit more stagered than that. and got about 2kw less.
then my last car before my skyline had a dead smooth curve. no rough spots. the dyno guy said it was one of the smoothest curves he had ever seen. it was a '00 magna with a stock ecu and full exhaust.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
