This is the question that current faces me. I have a custom 3inch exhaust system end-to-end, & also a 'complianced' cat which sits in between. Do I get a 'hi-flow'cat? or do DIY using broom stick method to remove the guts of the cat!!
I am interested in hearing people that have done this? Did you experience or notice and problems after? I note 1 persons previous comments on backfiring..
People have told me that if I were to change my cat, to hi-flow, I would notice a big difference in power. Wouldnt removing the guts of the cat make this the ultimate 'hi-flow'.
I note that many people have bought either the Catco or MetalCat during previous group buys - so I am sure there would be interest out there?
It's highly illegal and quite dangerous to remove the internals of a cat.
Cats are designed to flow.
If you gut the cat using the method you have suggested, it will interupt the flow, not increase it.
However, if you would like to find out first hand, and risk a massive fine, as well as risking inhaling the carcinogens contained inside the cat, then by all means go for it.
:laugh:
Unless it's a track car, get a proper high flow cat.
there has been a few threads on this.. some even went as far as to dyno the difference from highflow cat to a straight through to busted out cat, the best was a pipe (straight through) then the highflow then the busted out cat.
I have looked everywhere for the link - could you please tell me where I can get this information you mention.
greatly appreciated.
i remember reading a very detailed thread on this - basically u dont want to do it coz its a crazy $10000 max fine or something like that...
and cops can tell by tapping on the cat if its hollow or not...
This makes sense because the compliance cat probably had a 2.5in inlet and outlet. The two step changes in cross section where it bolts up to the rest of the system will hurt flow, as turbulence is created up and downstream of the section change.
The original poster should bite the bullet and get the catco or metalcat. Better performance, no fines, and wont screw up the environment. Reaming the cat is the way of the bogon....you're better than that.
Rgs,
Kot
Edited by MrKotter
I recently went to get a tune and found out my cat was restricting my power i then asked "could you just gut it" the mechanic then told me that they normaly put a straight pipe right through..(didnt reccomend it)
long story short. he gutted it for me and got an extra 5kw out of it.. but its just a temp thing im recivein my new 3" highflow tomoz.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
