Deca November 2006 - Convoy Cruise Saturday Morning
Hi All,
This is for all the people who are just going up to spectate/help out on Saturday.
If you are leaving on Saturday morning and competing you'll have to leave earlier to
make scruitineering, about 5:30ish I been told but that’s too early for us spectators :D
When are we leaving?
Saturday Morning - Depart approx 8am
Meeting point address:
Shell Roadhouse
Hume Hwy
Donnybrook VIC 3064
Melway 365 C5
Meet Time:
7.30am
Depart Time:
8:00am
Bring:
Adequate Fuel
CB Radio - Channel 14
Tour Leader:
The person who has been there before or knows the way :(
I am and everyone else I talked to who's going up Saturday is pretty flexible with times so if you wanna leave earlier (not too early) or later we probably can :cool:
its pretty easy, from that meet point drive on the hume
theres a turnoff for shepparton, take that left (the exit ramp is about 70k's odd from donnybrook)
then head to shepparton. note lots of speed cameras on the way
its about 1.5 hours from donnybrook to shepparton
once you are in shepparton
most of the guys hit maccas in the morning for breakfast
youll see the typical bunch of skylines, wrxs, evo's etc in the carpark.
if not, keep driving through shepparton, till you are almost at the end of it
the road is called wanganui rd, its a left, on its sign post is a blue "DECA" arrow signpost.
take that road for about 2 minutes, take the 2nd entrace (car entrace) and we are there in the car park
if you get lost 0404 TINT 99
My mum is bringing mini dezz up on saturday morning to watch and have some passenger runs (gotta try scare the shit out of my mum on the skid pan :laugh:) So I might tell her to meet up with you guys on saturday morning :D
its a convoy cruise to our motorokhana weekend in shepparton.
its just easier to go down there in a bunch of cars instead of driving up by yourself. you are welcome to come and specatate on the saturday if you wish
Guest
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
