Any sugestions to more midrange for the circuit,
Power FC
550 inj
Walbro - soon to be upgraded to surge tank supply for bosch item.
tien coilovers
Fmic Hybrid
EBC Hybrid dual stage
Complete exhaust system with HKS super dragger & magic cat
There is a heap of other stuff but had a few rums so Ill leave it at that.
Well back to what i need to ask is will the poncams in anyones opinion give me the midrange I want or will it take to much out of the top endpost-25783-1163502867.jpg
https://www.sau.com.au/forums/topic/143321-hks-gtrs/
Boost seems fine. I would suggest some cam gears and a retune would get you some good midrange, but also 260 degree Poncams will give some and not to mention some more top end. Do both and the world is your oyster. :)
Oh and no need for a surge tank. Ditch that walbro and get a second hand GTR pump or some other pump that will do the job.
https://www.sau.com.au/forums/topic/143321-hks-gtrs/#findComment-2672675
