mines 4 inch. although it looks abit funny having a ugly reducer on the end if you have a afm
So have the thing flare from 3" --> 4" near the turbo inlet like me :P
true, but if you have an air box setup you wouldnt really need to SEE the reducer.
my airbox has the AFM and filter inside it, and the hole is at the 4" section, so you cant see that its reduced at all.
My turbo is 4 inches on its intake, how big should i make the intake pipes??? If i use a Z32 which is 80mm, so say 3 inches and then size it up?? Maybe having a 4 intake pipes all the way is an overkill?
Hey,
if you can, you want to expand it gradually (more gradually than other pictures show). If you have
the space, try for the 1" expansion over 20cm or so - in general, the shallower the expansion angle,
the better.
This becomes harder if you have to curve it at the same time :verymad:
Regards,
Saliya
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
