A few people have shown an interest in my new little toy - the Orange TPMS (Tyre Pressure Monitoring System) and wanted to know more about it. I must admit I first heard about it fro Jeff Beable who runs one in his Targa car - but then also was shown 1st hand the effectiveness of them on the Maserati Quattroporte James and I drove which told me about the flat tyre before I realised.
I'll have it on the car this weekend at DECA to get a real feel for how good it is but basically it's a little gadget which has sensors fitted inside all 4 tyres which then provide information on both tyre pressure and tyre temperature to you live in your car. You can also set "alarm" points for low tyre pressure and high temperatures.
I got mine from Bit Distribution in Bayswater for $315 - Bit Distribution
In the last 12 months or so I've managed to delaminate a number of semi-comps on the skidpan basically from over heating - so I'm hoping this will help stop me from doing that. Also - earlier in the year I destroyed a tyre from driving on it flat (sidewalls were so hard I didn't realise it was flat until it was too late).
So pretty much if this thing can save me 1 tyre it will pay for itself. Also it means I don't have to get out and check each tyre regaularly on the track and can also get a better understanding of how quickly tyre temps come up and go down on the track because I can see all the data live. It will also show me if my tyres are overheating due to excess wheel spins on the skidpan.
More information on the unit is available from thr Orange Website here - Orange TPMS
https://www.sau.com.au/forums/topic/143398-tpms/
Hey Snowy
Ive had TPMS on my 34 for the past 12 months, its a very handy gadget :P
Mine is a little bit different as it displays all tyres at the same time, its seems the one you have displays one at a time
Ive attached a pic of the display, note pic shows tyre pressure in bar but is selectable to psi
Cheers
https://www.sau.com.au/forums/topic/143398-tpms/#findComment-2679286
how much 4 ur one CNBLOW...not that I need it, but I like buying stuff.
actually as Snowy said, I had the issue of driving on some low profiles and it was flat and I didn't know....wellldidn't know until I went around a corner and the tyre came off and I just missed an oncomming truck as I span out...not cool.
https://www.sau.com.au/forums/topic/143398-tpms/#findComment-2679581
Details would be great,
One of these would have been handy when my tyre went down through the flip flop at calder!
https://www.sau.com.au/forums/topic/143398-tpms/#findComment-2679620
hey guys
The TPMS i have is direct from the manufacture, i did extensive R & D for more than 6 months on this product alone working in conjuction with the manufacture to get his product 100% (ie software bugs)
If people are intrested in the product, i can try and find out some prices if needed
In the 12 months i have been using it, its never failed once
https://www.sau.com.au/forums/topic/143398-tpms/#findComment-2681898
hey guys
hey mate
details...who makes them and roughly how much. where are they located?
the other one Snowman posted is pretty wicked though. Reading through the install manual it looks pretty easy.
Hey Snowy...does the trasmitter sit around the existing tire valve..i.e. the valve stick through...I couldn't work that out. I saw they installed it from inside...not sure how its gonna look I wouldn't mind I pic. The dispay unit looks tops though.
KJ
https://www.sau.com.au/forums/topic/143398-tpms/#findComment-2682911
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
