  • 8 months later...
  • Replies 93
Why does everyone want gay stainless steel manifolds that crack etc heat fatigue, 6 boost manifolds and ones made from steel are 10 times better in theyr can b heated and cooled alot more times without damage plus they have been found to retain more heat and decrese spool up times of liek 2-5% percent from memory because they retain more heat the exhaust gas flow is quicker theirfore making the turbo spool faster, the only downside in weight thats all but if ur actually going to drive ur car ie do afew km's in it wouldnt u want something that is going to last....
Thanks Rory
note a link for some 6 boost manifolds:
http://www.horsepowerinabox.com/HPIAB2/category15_1.htm
i want a 6boost one but there is a bloody 4-6 week wait on them. i need my car back now as its my daily driver and its in peices as my stocker is cracked...
i have been told that the stocker will only crack due to running to lean....??? any comments?
I have recently had my 6boost (SR20) ex manifold and stock SR20 inlet manifold honed by Andrew Sanders (along with my turbo compressor cover). I don't have the before/after flow results on me but will post up later for anyone interested in this process.
OK for what its worth 6Boost ex manifold and standard blacktop inlet manifold (SR20) before and after extrude honing at 28 inches. Please note that my mandate to Andrew Sanders re exhaust manifold was not to equalise flow as I didn't want to increase the volume too much in runners 2 & 3 and loose any response. And my mandate re the inlet manifold was to equalise flow - which is nearly perfect. Just an example of the benefits of extrude honing.
6 Boost Exhaust Manifold
Before.............After
1 250............260
2 220............245
3 222............247
4 252............262
Standard SR 20 Blacktop Inlet Manifold
1 254............300
2 257............306
3 270............306
4 254............300
For comparison sake I pasted this RB exhaust manifold flow data previously posted in this thread but Im not sure at what pressure the flow tests were done?
Some flow rates for you guy's from extrusion flow honing standard manifold ,hks cast iron manifold and hks cast iron flow honed
standard manifold .........hks cast ...............hks cast flow honed
1 159.7.........................170.7............................194.8
2 162.4.........................166.6............................203.4
3 160.7.........................178.7............................198.7
4 150.1.........................183.6............................200.3
5 149.9.........................182.2............................207.8
6 173.3.........................184.7............................202.8
^^^^^ agreed but IMO the 6Boost manifolds has one of the best collectors in the business. Mercury Motorsport made 562 rwhp from their stock stroke sr20 with a 6 boost mani and GT35 turbo. This car also ran 10 sec quarters with manual box.
My manifold is also unique in that it has been custom made to suit one of the new round collector v-band Tial cast stainless housings for my HKS GTRS turbo.
Edited by juggernaut1
Suggest you get in touch with Leigh from Extreme Turbo Manifolds if you need something sooner. The link is in my sig.
Found this link on power porting process of before and after hp figures done on a test mule RB30 engine when Specialised Power Porting was in its infancy.
http://autospeed.com/cms/A_0622/printArticle.html
  • 1 year later...
a bit of a update on a old topic but...... i just spoke to Abrasive Flow Engineering who does or did work for uas on hone and extrude and his exact words are for a rb25det manifold.
"""don't wast your time and money they don't flow as good as a hks manifold ""
and
"""for $900 to extrude and hone i would go and get some thing better"""
f#%$ me.this is from the guy who does them while some companies are begin for work due the the $$$$ crises this guy has shocked the sh#@ out of me so ..........after reading this post and many like it over the years and looking at the figures people have posted on flow have we all been grossly mislead by people in the industry have figures been made up for the trusting customer.
what is one to thing !!!!!!!
if anyone does reply do it here.: http://www.skylinesaustralia.com/forums/Ex...47#entry4450747
Edited by WARLORD
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
