Hey all,
For sale is a surge tank setup with a Genuine Bosch 044 pump and all fittings needed. The tank is a 2L polished RPM EFI unit with 3 dash 6 fittings at the top and one dash 8 fitting at the bottom for the pump to feed off. The fittings on it are the Proflow Engineering fittings and the pump also has its own anodised bracket.
Everything here is brand new and unused, only pulled out to see what it looked like!
All thats needed to get this setup going is a bit of hose and 12v!
NOW $500 for everything here, im also willing to separate but prefer not to.
Located in Melbourne, I dont mind posting.
Thanks!
Mat.
0400 558 030
Edited by femno
https://www.sau.com.au/forums/topic/143583-surge-tank-and-044-pump-setup/
  • 1 month later...
  • 1 month later...
Sorry for a possibly dumb question but what will a Bosch 044 pump flow Hp wise. I need 600hp pump at least for my current application.
Thanks
The 044 will flow up to around 600HP as far as im aware, maybe a little more. This setup is a must for any highly modified vehicle to eliminate any possiblity of fuel starvation.
044 for sale: click my sig link.
All still available.
Hey. I am in the United States. I have calculated shipping costs via EMS from there to here. I will give you $575 AUD shipped to me for it. I have money in hand and can pay by what means you prefer. Thanks for your time.
Edited by Ramius83
  • 1 month later...
Do you have any more info about the surge tank? Manufacturer / Model?
Yes it is an RPM EFI branded surge tank, 2L capacity with dash fittings. Polished Aluminium.
  • 3 weeks later...
  • 1 month later...
  • 5 months later...
  • 1 month later...
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
