Items:
A cheap daily car
Extra Info:
Its better to be manual, hope can be FR, but not necessary. Hope can be under 200,000km, must no more than 250,000km.
Contact Details:
PM me or email to [email protected]
Price and price conditions:
If its a normal daily, hope it can be under $2500, if it is something like N/A Skyline or S13, can go up to around $5000.
got one clogging up 'my" part of the shed roo.
The snorkel has been modified slightly to allow for intercooler pipe to go under it.
Flick me a pm. Would like to be able to borrow if if i ever needed it... Dont see why though.
Also have a Hi flow Blitz filter for it that done less than 5K.
well some dickhead mod deleted my thread in the main section so i guess here is gonna have to do....
i need a rb26 injector ASAP, today or tomorra at the latest. or if someone can recomend a set of replacements, or upgrades with the same flow rate...
cheers
rhys
For calling any mod (especially me) a dickhead, have a 10% warning and you should feel lucky you don't get a 1 week holiday from the forums. I was going to go easy on you, but since I have seen this comment ....
So, I am a dickhead because I deleted a thread in clear contravention of SAU rules .... even though everyone else does the right thing .... why do you have the right to post a wtb thread in the SA section and everyone else (including me) doesn't? I don't care how urgent it is ....
wtb:
front discs for r33 gtst in good condition, must have enough bite left in them, don't want cracked/warped discs obviously.
i know its something best to buy new but am really low on $$ and need some decent used ones in the meantime.
PM me thanks
wtb:
PM me thanks
got some so ignore this ^ post
cheers Steve.
Am looking for a stagea in south australia, am lookin to swap my rx7 (modified) plus cash ure way. Looked on carsales ect and no ones interested in swaps of any kind so i thaught id ask here. PM me, if cash sale only, send pics n ill have a look so that if i sell my rx i can consider it.
Cheers
(anyone with a stagea let me know as have a fair bit of interest in the rx so when sold will have finances)
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
