hi pplz i need a gts4 or gtr gearbox for parts.
show me what you got and how much.
thanx
as soon as i get my tax return (i lodged it late) i'll be paying off a 33gtr box i'll be fitting to my 32. my old one will be available then. gears are good, synchros are f**ked. pm me for more info
-D
I need some r33 gtst castor arms not too fussed about condition ( will fit new bushes ) aslong as there straight!
will consider swap for some kazama pillow ball arms if yours have new or near new bushes fitted!
Edited by 180or200
^^ if he doesn't want it i need one of those inner guard vent things
hey steve i had a look out in the shed for the inner guard but the one i have looks different it doesent have slots like that it has a square hole with mesh in it . it's off a r33 cheers dean
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
