want to borrow:
Girl, must be hot and good in bed. 18-26, attractive.
Pm me with offers
ah the old can i borrow you. only for an hour or so. but can you make sure the dishes are done by the time you leave. thanx :devil:
Im after a 3' Bellmouth Front/dump pipe for my s1 stagea (rb25)
ive got a bellmouth/dump/frontpipe off my r33 sitting at home made by boostworx
only problem is it was made for a highmount set up, but you prob get them to cut a section out and weld them both back together to make it shorter
the dump flange is for a standard rb25 turbo
$30
Edited by ovrtym33
$30
I think by the time I buy yours get them to mod it to a standard mount turbo it will be more than the $200 odd dollars it will cost me to buy a new one :(
$30
Got a pic of it? If its a high mount, won't the ex housing be rotated in the wrong position for a low mount turbo? Interested.
On that note ...
WTB split dump pipe or similar for RB25DET to replace stock dump pipe.
On that note ...
Can't edit, so here's a pic of what I'm after.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
