Neither my GTR box or clutch kit came with a thrust bearing collar (or 'throw out bearing collar'). Does anyone have one lying around?
:D
youd want a brand new one , go get one from koji at import spares , about $50 for genuine nissan one :)
then youll have to go get it pressed with the old collar , i got andy from autosolutions to do mine for $20
looking for a cheap run around car
would like to have a/c and be manual
looking out for kei cars like mira's etc. but wont be overly fussy
wanna buy my 85 corolla? lol its a manual, a/c dosent work tho $800
lol steve i wouldnt been seen dead in a sigma haha and the BA says in the add typo like you said, meant to be 10k otherwise that would have been awsome
lol get this it comes with 1 complete good side
>>oops<<
i dont even think duck tape and/or zip ties could fix that haha
had a 92 rolla before after selling the 32, didnt really like it :P
Buy my ute, its got no A/C and its not manual :) but its a ute, great for towing your pig13
selling the 13 soon too once i get around to putting it up for sale. plus id like to have some room for more then 2 people as ive already got a ute here :P but thanks :D
probably should have added to the add, cheap on fuel or even gas.
thanks guys
Edited by Import S13
