Looking for a oil cooler anyone help .
yes! i have one i probably wont use. decent size, braided lines, relo kit included. pretty oily, but barely used. paid $300 for it so i guess that much?
Wanted: Drivers side headlight for R32. My car is a 1992, I'm not sure if the style of projectors changed over the years, unless anyone can shed some light on this?
let me know of a price :).
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
