Hey guys, need the following for my 33 GTR:
Brembo brakes
Bride seats
2.9L motor
Kakimoto exhaust
Gramlight wheels
I need them asap and will pay stupidly good prices for them because i am so desperate and vulnerable.
Thanks
Looking for 4x 60mm spacers. I doubt anyone will have any lying around but just though I'd ask. Also would wheelworx make some tha big up?
You MOST DEFINITELY do NOT want 60mm spacers .... even 30mm bolt-ons are pushing the limits of wheel bearing capability and safety.
Buy some wheels with the correct offset for your car ffs.
yes wheelworx can make them up for you, yes its gonna cost, and yes you do not wanna be running them on a car unless you got some custom heavy duty bearings and shizz...
if you got a 4wd on the other hand, big spacers are common place afaik.
pete not keen on 34r rims?
Adrian, I know your selling yours but they may be a bit more than what I want to pay + they are only 9" whereas I was hoping for a smidge wider
How heavy are they compared to a TE37 (1 piece forged alloy monoblock)....if they were a similar weight and the price was awesome, I could consider going for 9's :P
what offset Pete
not really sure Steve (guessing around +30 or +35)......they have to fit over Brembos & 355mm rotors
exhaust system can be stock or aftermarket just somthing around 3 inch thats cheap
intercooler kit with piping or if you have an intercooler without piping or just the piping just let me know anything will do
need these things by next Saturday!
sorry guys these parts need to be for a 33 cheers
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
