WTB URGENT: r33 front lower control arms!!!
will pick up or pay for post or give sexual favours!
cheers
oi dude, read not long after your last request, someone had asked which side(s) you needed
have a chat to mitch
Urgently need a R33 gts-t manual gearbox asap or Steve is going to miss out on gazzanats and cry himself to sleep for the next few weeks.
If you have one please pm me with a price or call steve on 0419446847
Thanks.
looking for a cheap boonga... has to be rear wheel drive, manual, and running.... body condition doesnt matter, interior condition doesnt matter.... defected and unregistered doesnt matter.. it will never see a bitumen road again...looking to spend between $0 & $250.. will pickup from most areas of adelaide.....
PM me or TXT 0410982366
WTB: Front or rear R33 GTR Brembo brake pads or front rotors
i dont think ive still got the spare pads mike gave me with the calipers, but i do have some rotors i found just before that came over with the car. compared them to stock, and they look bigger than stocker 32r rotors. should compare them to my 33r rotors, and if they're any good u can hav them :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
