After the following parts to suit r32 gtst
r32 gtst (or GTR) Drivers door - prefer black, in good nick
r32 diff - std one required for regency. I can shim it, so worn ones are ok
r32 gtst - tail shaft. One that runs from the gearbox to the diff, not the sub axles.
Have exams on this week coming, so can pickup anytime after friday.
I got the center of the diff pm if u want it
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
