Chasing some tomei pon cams for my S2 RB25DET. Looking for: 256 degree rotation and 8.5 mm lift for both the inlet and exhaust.Pm me what you have.
Thanks
Adam
Also after some Nismo side feed 555cc injectors for a rb25.
Adjustable and rose jointed caster arms for a HR31
Cheers
WTd
Good nic r32 front guards
r32 driver seat
r32 gtr front bar
r32 front brakes mspec or r33 fronts
Adjustable rear camber arms
r32 front stif shocks or coilovers
Are you saying want to buy or want to donate lol?
WTD=Wanted
WTB = wanted to buy
So yes anyway also after 32 intercooler kit aswell
i have fmic kit om my car and looking to change the setup.
something like blitz or associated brand. also have lowered sus in the car and looking to upgrade to coilys
make me an offer and you can come see them on the car if you wish
After a RB20DET and running gear to go into a S13. Need everything; crossmember, ecu, loom, gearbox, complete motor, tailshaft etc. Also chasing a S13 manual pedal box and master cylinder on the off chance anyone has one. Best point of call is pm or sms on 0424 085 308.
In need of:
Surge tank
external fuel pump
fittings
or all above as a kit :)
side feed intake manifold for rb25 s1
that would be it for now :)
Just to clarify on the fuel pump bit, as I just found out, ill be needing a minimum of a bosch 044 or equivalent and at least 2L capacity surge tank :( if anyone has anything let me know asap otherwise ill have to ditch more cash at the hunk and go buy new stuff this week :wacko:
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
