Still looking for an RB26DETT motor - prefer R34 but R33 may do... let me know what you got!
Hey Vu, contact Alex (GTR1993). He message me the other day asking if i knew anyone that wanted a 26 as he has one that he's looking to sell.
http://www.skylinesaustralia.com/forums/user/29334-gtr1993/
looking for r34 4door side skirts if anyone knows of any even damaged ones please pm me...cheers
I have some R34 4-door side skirts (I believe they're fibreglass not plastic) in Sydney at a mates house - he picked them up from a 'local pick-up only' eBay auction a few years ago for me. Been sitting in his garage since because I never got around to couriering them.
Thread: http://www.skylinesaustralia.com/forums/topic/373325-r34-sedan-sideskirts/
Im after:
2 child restraints
high mount brake light
Tyre placard
Im sure there will be more parts as I think of them,
:thumbsup:
hi, i have an r33 s1 coupe, looking at buying a front bar KH2 grey, the current one i have looked like 400R n its way too low and has cracks in it.. I was looking at a type M bar? i need it to fit fmic.
also looking at maybe getting a boost controller to change the boost up and down and to see what boost i am doing on my stock turbo but it has the rb32 actuator?
maybe an ecu tune of some kind?
REPLY ASAP WITH INFO PICS
Wanted R32 LH headlight, doesnt matter if its smashed, broken ect, I need the projector globe retaining clip, putting my 32 back together and have found im missing the retaining clip for projector globe.
Wtb: Track rims and tyres to suit GTR, 17" or 18" condition of any kind, scratches, gutter rash etc doesnt matter just no bent/buckled rims for obvious reasons hah..
Please PM me with what you have,
Cheers
WTB: still chasing a S1 R33 front bar, must be able to fit FMIC, must not be too big, and preferably KH2 dark grey s1 coupe color. NEED THIS WEEK, will need to come with indicators and all wiring/and or clips to fit onto my car !!!!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
