I was on the pushy and road past u a couple of times checking out the car. I was actually waiting at the intersection of anzacs and brighton when Niel put his lights on, went through a red light and chased u down. :(
serious? i didnt even do anything wrong though? i wasnt hooning or anything but by the sounds of it he must have had a hard on for me?? first defect in my life and owned sklylines for 7 years now :(
officer f**kwit Neil likes to pull over n defect Skylines for no reason, did me for same reason
and to think some of the Skyline community wanted to work out a peace offering with him a long time ago, what a joke
Happened to me on Saturday. Tried to do me for my stock bov, tried doing me for "drifting on full boost" with my daughter in the car (you think im that stupid), then reached down and pulled up a manual boost controller from under the turbo and major defected me for that and that alone. Even though i had am performance blast pipes and coil overs. Major hard on.
Frankly considering this blokes hit rate, I would be tempted to elevate a complaint to the police ethics board.
Once you get in front of an independant adjudicator and compare the ratios of his defections, and the defections on skylines in particular, i think then it would possibly show some statistical outliers which would have to be explained if the media were somehow incited to get involved (aka some indignant TT/ACA piece about road taxes and yet we still drive on shit roads)...
That aside, There's nothing wrong with law abiding citizens that love cars to approach the law and say 'we plan to do this, lets plan it so as few people are inconvenienced as possible'. The gesture is grand but sadly some station commanders enforce quotas and then there are also rogue police that have a bugbear and use every one of their legal rights to screw the enthusiast. There are many grey areas and you really cannot win... I've even had my sapol cousin in law say as much...
-D
-D
not wanted, its needed!!!
need R32 bonnet, bonnet latch and the upright and mount to the rad support, drivers head light and a Radiator,
need it all asap, have to fix my car by sunday
very desperate, and would prefer to help clear people sheds out instead of wreckers
Hi all
Looking for a few items for r33gtst 2door
Aftermarket front bar unpainted or preferably black good condition not hacked out
S1ors2 dash trim pieces in reasonable condition suit clean an spray
Aftermarket steering wheel boss kit suit non airbag hicas
Piggy back ecu + harness if needed to suit rb25det
3inch Hi flow cat suit r33
R33 aftermarket 3inch dump, front pipe
Nismo style r33 grill or black s2 grill
If you have any items i am interested in shoot through to me on
0413863525 or [email protected]
Cheers
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
