URGENT!!!!
Need r33s1 waterpump in good working condition.
need asap due to vehicle running out of coolant and its my daily driver.
contact me on 0422360999 (text me thru the day untill 510pm) need by friday/saturday
Cheers aaron
Hi guys
Sadly some a**hole stole my R33 and took it for a whirl and helped themself to some items. Also sadly unsurance are being dogs and wont pay out on a technicality. SOOO i need some help im after the following:
R33 series 1 Front bar (can be any type prefer white if possible... also i have a front mount if they will affect anything) hell ill even make a series 2 fit lol
New airbag (was stolen)
new ignition barrel
Boot carpet (they pulled out the custome interior i had..) also need the panel that covers the battery area as well.
spare tyre/jack if theres one floating around.
any help would be HEAPS appreciated. im based in Klemzig area as well
Hi guys
new ignition barrel
sorry to hear man,
got spare boot interior except bit that covwrs battery...
new ignition barrel
Ive got a passenger air bag out of a series 2 also have a spare jack.
R32 gtr apexi pod filters. can get new for 280 online so if anyone's got any better pm me.
Hey sean, just a heads up, the 3A Filters from supercrap/autobarn are rated better than the apexis and only cost $30 each... Wheels did an AFM shootout a few years ago and they slaughtered the apexis in terms of filtration and airflow...
http://www.australianauto.com.au/HTML/Images/Air%20Filter%20Shoot%20Out.pdf
-D
i would guess the slower the flow the quieter the induction noise
Theres really not a huge amount of difference in noise that I can tell... I run Trust M pods atm but will be replacing it with the 3A - 3A filter is a dry type (no oil required) so its a little friendlier on your air flow meters (oil from filters can accumulate and get baked onto the afm sensor wire)
-D
legends. hey ben you still want that steering wheel ? your in town now ey. ive still got it, it didnt sell with the 33.
might go get some of the 3A filters one night this week. cant stand the standard airbox it makes no noise what so ever haha.
lack of noise = police friendly. I'd be going for lack of noise as long as it doesnt compromise performance.
Going from box to pods doesn't make that much of a difference in terms of noise (that I've found) but they do make a diff in performance (relatively speaking, the arc air filter/custom box is supposed to be good but I know nothing about it)
Pods are easy and cheap to replace, but you have to go to the trouble of making a cold air box and intake duct to isolate them from ambient engine bay temp, whereas a box filter generally has this by design - which is why the aftermarket hiflow filters that slot into the stock airbox are popular but again, i know nothing about them...)
-D
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
