mike,
The charcoal canister has a breather pipe that goes back to the fuel tank and a couple of pipes at the top that draw from the manifold.
You can simply block all the pipes. The only drawback is the fuel tank may make noises when opening it (not dangerous).
(many cars have had this canister since the 70's as a polution control device) all the performance cars I've owned I had the canister disconnected .
The benifits are one air less leak to the inlet manafold there is a little performance gain not much tho, I'd imagine the fuel tank would no longer see turbo boost.
more room under the bonnet if the container is removed all together.
removal/disconect dosent affect emisions measureable at the tailpipe as the idea of it is to take fumes off the top of the fuel tank and stop the tank Pressurizing.
if you leave it venting to atmo & cut and block the pipes going to the inlet the tank wont make that funny noise when opening.
Micko, a couple of people I've spoken to said that this is the first thing police look for, and that they do know what/where they go; mainly since it's emissions control
not sure of the fines, and not sure if this is true as I haven't been pulled over before
At the same time, I can't really see much of a performance gain from it, since from what I can see it's all from the plenum, and whether the air goes down the pipes to the carbon canister or with a blocked pipe, shouldn't make by any means a detrimental effect on anything
just make sure you plug up the hoses if you do remove it :D
Guest INASNT
First thing the cops and the epa look for.
Also if its disconnected permanantly then u will get petrol fume smell coming in the car when u are reversing and when u r stationary
    • Yeah, I guess its pretty easy to get to if this doesn't work. Just wait till next oil change and pull it out. I am going to have to do the oil pan gasket soon and thought I'd just replace it while I was there.  Thanks
    • All that matters is you're safe and you were able to type that post. Hopefully heaps of parts you can recover for the next shell.
