mike,
The charcoal canister has a breather pipe that goes back to the fuel tank and a couple of pipes at the top that draw from the manifold.
You can simply block all the pipes. The only drawback is the fuel tank may make noises when opening it (not dangerous).
(many cars have had this canister since the 70's as a polution control device) all the performance cars I've owned I had the canister disconnected .
The benifits are one air less leak to the inlet manafold there is a little performance gain not much tho, I'd imagine the fuel tank would no longer see turbo boost.
more room under the bonnet if the container is removed all together.
removal/disconect dosent affect emisions measureable at the tailpipe as the idea of it is to take fumes off the top of the fuel tank and stop the tank Pressurizing.
if you leave it venting to atmo & cut and block the pipes going to the inlet the tank wont make that funny noise when opening.
Micko, a couple of people I've spoken to said that this is the first thing police look for, and that they do know what/where they go; mainly since it's emissions control
not sure of the fines, and not sure if this is true as I haven't been pulled over before
At the same time, I can't really see much of a performance gain from it, since from what I can see it's all from the plenum, and whether the air goes down the pipes to the carbon canister or with a blocked pipe, shouldn't make by any means a detrimental effect on anything
just make sure you plug up the hoses if you do remove it :D
Guest INASNT
First thing the cops and the epa look for.
Also if its disconnected permanantly then u will get petrol fume smell coming in the car when u are reversing and when u r stationary
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
