change your gearbox oil frequently and you will never have the problem.
BTW the redline stuff should be changed just as regularly, so unless your made of money I'd get a couple of different grades of cheap stuff and see what works.
strich9ine,
your not supposed to flat change into 5th its only a 'little gear' :P
https://www.sau.com.au/forums/topic/14400-klunkety-klunk/#findComment-291104
hmmm, what is this "flat shift" you speak of? heheh. nah, was like that when i got the car!
puckish,
locktite cross thread stuff eh?
I need this stuff called BruteForce to get the freakin thing undone first.
Oh yeah, and i need to know how many Litres of oil i need for gearbox.. i only have 4L! (thought about that after i bought it)
https://www.sau.com.au/forums/topic/14400-klunkety-klunk/#findComment-291224
Pacey,
Your bearings need replacing. That is the first signs we got when both the R31 and a VL 3ltr boxes were on there way out. Both just needed the bearings replaced. Both were manuals too. Eventually it will become louder.
https://www.sau.com.au/forums/topic/14400-klunkety-klunk/#findComment-295135
Yup, my bearings are gone too, not too loud atm, but it'll get worse I'm sure..I will be replacing them when I get my new clutch.
Oh yeah Strich9ine, you will need approx 2 litres of oil for that box..I will be doing mine soon too, I bet it's on the original oil..
https://www.sau.com.au/forums/topic/14400-klunkety-klunk/#findComment-296670
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
