Ive notice in the last couple of hotter months, my car in traffic (heavy peak hour), when the temperatures in excess of 34, all of a sudden starts idling like a rotten piece of crap (heaps low idle like 400RPM) and taking off is rediculously doughy and sluggish. Then ill get home lift the hood check all the cooler pipes etc and they will be rediculously hot (as to be expected tho) and the heat shield will be "tinging" (cooling metal) to all buggery. Im just wondering if anyone else gets this, or what i should do to help this, or if turning the aircon on to get some additional airflow in will help ( i kno this helps in other cars as it switches on the aircon fan which draws cooler air in to the engine bay).
Cheers, David
https://www.sau.com.au/forums/topic/144094-hot-weather/
yeah my R34 doesn't like it much either .... but is fine as long as the car is moving. But still, I am going to take off the stock crank fan, and put in a heavy duty thermo fan. I am also going to rig up some sort of fan on the air conditioner radiator/compressor. When my car gets too hot while idling, the air conditioner actually turns off (hot air comes out) - I assume due to some over-temp safety mechanism. If I get out and pour some water on the radiator and air conditioner condenser, the air conditioner fires straight back up and works a treat for a while - the car seems to run better for a while too. I am also going to rig up a big water misted to spray the radiator for really hot days like I had on my S15.
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2691826
cool, thanks Joel. Yeah I am thinking I will grab a JustJap alloy radiator, Davies Craig 20" thermo fan, bigger condenser fan, Davies Craig trans cooler (already have, just have to fit), and oil cooler (already have, just have to fit) then I will be all set for summer :)
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2692304
I bought my 14" thermo from atracing on ebay.
From memory it was ~$80.
The fan wasn't a straight blade it was a curved blade.
Looks identical to this one.
http://cgi.ebay.com.au/HIGH-PERFORMANCE-14...1QQcmdZViewItem
What ever you get be sure its a curved blade fan, they push a lot more air and they are quiet.
Those justjap alloy rads are a bargain.
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2692402
dont forget coolant flush if you havent already, car will love you for it.
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2692661
put the heater on, that helps if u can put up with the extra heat in the cabin. it draws the heat from the cooling system so in theory it draws heat from the engine which should make it run slightly cooler.
with my car, heat naturally goes into side the cabin where the foot area is. and i press the recirculating air button so that it blocks it from coming in.
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2692667
what about the affects of different temp on boosting.
I'm only mentioning this because I have heard that thick/thinner air accompanied by the factor of its temp can potentially damage or over power a car that is not set up correctly or doesnt have the appropriate management systems in place.
Edited by SAZilla
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2693681
MMM, i would be worried bout anything else, but the idle was casuing the only real concern for me. Ive just set up a new CAI for the 32 hopefully to lower the intake temps marginally, guess we'll see. So no one has had the idle problem tho??!
And really the only solution is to get a bigger thermo fan or the like?
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2694091
nightcrawler = used to have the pewter s15?
if so, this is andy, i had the R33 GTR (midnight blue), with Matt's 33 gts-t
i see u're still on the forum
we havent been on here for like 4yrs now..time just flew
howz the family?
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2695138
ahh how you doing mate? Yes it is me, and I still have the pewter S15 (want to buy it? lol) .... yep things are good - the usual : work hard, play hard - we have just returned from a week in Singapore, I spent a week in New Zealand skiing in August, and we spent a month in the USA last September. Work is good, but busy and no kids on the horizon just yet (thank goodness) .... how about yourself? Did you sell the GTR?
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2695152
had? what happened to it and what your cruising around in now?
i remember last seeing you (bout 3 yrs now @ bp) with a female and your car had twin pipes then you dissappeared.
https://www.sau.com.au/forums/topic/144094-hot-weather/#findComment-2695353
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
