Paul22, this may interest you!
"L28 TURBO ENGINE 4 SALE - This engine was built by SWR & runs a P90 turbo head, T3 turbo, EFI manifold with 300ZX 55mm T/B, Wolf 3D ECU, FJ20 turbo injectors, electronic ignition, 125kw@w on 8psi boost & has only travelled 15,000 kms. It also comes with the electric fuel pump & swirl pot, a 2.5" exhaust system & the modified rev tacho. Engine is still in the car (260Z), can hear it run & test drive. All relevant paperwork & receipts are also available for viewing.
Price: $4500ono Location: Wollongong
Contact: Nick Email: [email protected]
Phone: 0416 283 194 (hours: 9am-9pm)".
Now, I know it's a Z engine & will reqire the sump mod which I will do if you're keen on this engine.
Ghostrider is right, this costs alot of money so be prepared to spend heaps.
Oh, & Ghostrider... 86mm/87mm pistons will go in a L24, I built one a couple of years back with triple webbers & it made 135kw@wheels, it's a daily driver & also does track work from time to time & is still going strong. However, I wouldn't do it to a turbo engine...
Nick.
Appreciate that but I am pretty keen to build my own engine and use my existing block so the numbers match. i understand that mods such as these require a lot of time and cash.
Thanks,
Paul
Nick.
Nick, your possibly right.
I could probably fit them into an L20A block too, but the water jackets would be a bit large.
Your quoting SWR as an engine builder? Stewart Wilkins will never recommend an over bore of 4.0mm in any L series block. The cylinder walls would be paper thin and very suspect to failure.
You might have done it, but I'm sure not going to try.
I have 2 x F54 blocks and they wont take a 3.0mm over bore, as I had them sonic tested to find out, as I was going to build an 2968 engine, but am settling for 2818 instead.
I don't know that these guys would want to be doing it either, but I suppose ANYTHING is possible if you want it enough.
Cheers, D
im wondering that too, theres a few L28 (carbied) engines at my wreckers.... i can get one for $20!!!
The factory cams have codes stamped in the back end face and the L24E cam is NOT really suitable for a turbo application, but it has been used in the past.
The best off the shelf cams are L28E and will have the markings A or F stamped in the back.
The A cam came from engines origin prior to 8/81 and were in N42/N47 & P79 heads and F cams came from 9/81 onwards in P79 heads only.
Cheers, D.
Cheers, D.
will the L28 cam go alright in a N/A l24e and what difference will it make
Make up your mind!
You going Turbo or N/a??
Best of best off the shelf n/a cams is the one stamped C and it was in all E88 headed 260Z.
It is reputedly the Nismo works cam.
Cheers, D
Ghostrider, I failed to clarify that the engine I built was 3mm over bore & not 4mm but have seen it done... I agree 4mm is playing with fire. In N/A trim 3mm is safe as long as the block is acceptable after sonic testing.
Paul... if you need pistons etc, I have a brand new set of 86mm with rings for $300.
Nick.
Nick.
Yeah! for sure.
I talk with SWR a lot and I was going to put an 87mm bore into my L20A and use sleeves, but the cost was preventative. The block would loose all of it's rigidity and it would be a mamouth task to complete and with custom liners, the bill would exceed $1500 after decking, recess grooving etc etc etc, so the F54 was obviously the better alternative.
These pistons & rings you have? Are they FLAT TOP and are the rings CHROME??
Cheers, D
Yeah! for sure.
Cheers, D
Pistons are dished & rings are chrome.
Nick.
Yeah! for sure.
Cheers, D
Just to let you know my plans, I'm building 2 N/A L28's at the moment using L14 rods. the 1st I'm using 86mm SR20DET pistons & E88 Skyline head with N42 valves (I believe it to be the best head combo to use), & the other I'm using 87mm VG30 flat tops with N42 or N47 round port.
Nick.
Make up your mind!
i am going turbo i just wanted to know if i can put the cam the engine now or should i wait till its turboed.
I will do a bit of hunting around for one of those 260z cams
Yes F54 block is what you want I think.
Lots of goof info on OZDAT forums
F54's were the 280ZX Turbo block and in turbo form, never came to Australia, but some of our n/a 280's had F54 blocks in them, but as far as I know, F54 blocks never came out in 260Z's.
And JC the cam would be fine, now or later.
Cheers, D
Just don't play your hand when looking for the 260 cam, not everyone knows, but I'm sure if you tell them the price will go through the roof.
The 260 cam has 256 duration and for your relative stock L24E turbo, it will probably be a little long and the L28 cam should be easier to get.
Cheers, D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
