Cruise & Camp (victor Harbor Or Other Alternatives)
If people are worried about reliability there'd be nothing stopping people from driving non Skylines. While the drive is part of the adventure, I think it's more the social side of things that comes first on this one :laugh: Just my thoughts, feel free to disagree.
Yes it is very much about the social side, just thought there should be a reasonable amount of driving enjoyment thrown into the mix too. I am a petrol head first & foremost over anything else so I always love a good windy road to zip along :( can't help myself.
  • Replies 70
Posted Images
Lets get back to reality here for a second.......
people are talking about accidents that have happened in the past cruises..... it happens no matter if we are on a cruise or not the danger factor has not changed...>>>> just a thought for some
As for parts...... does every body drive SH*T boxes???? My car is a track orantated car and im confident that were ever we decide to go it will make it no worries...... if you dont think it would make the trip bring another car or fix your LineSky!
Yes I need to get another g/box in to mine.
RB20 5speeds have a habit of being fine one second and bang no third gear the next behind the rb30det. :P
Definitely concerning how there are no signs that its going to let go, and more concerning you don't have to be up it for it to let go. :S
definitely go the auto Joel .... for $2,500 you can make an R34 Tiptronic auto absolutely bulletproof - kelvar plates, upgraded belts, modified high-stall and all the trimmings. I am pretty sure Mike from MV Automatics at Blackwood does stand-alone brains that can run the box all on its own, so wiring wouldn't be an issue. I am sure you could even rig up some steering wheel gear controls. Needless to say your car would be an absolute weapon when you do your final tune setup with an auto box .... very easy 11s I would think.
I'm actually toying with the idea of picking up a cheap Auto R32 GTS4 next year and dropping an rb30 in it with a 26 head.
Would be a damn fun little toy thats for sure. Some of you may ask why not go a newer Skyline.. Priorities.. :rofl:
on a side note -skyline- im working on a signature of your car taken from SCS as ive just formatted i dont have everything back on here yet ill post it up soon
yeah joel get the GTS4 that would make a monster car and being R32 you can wire it up to be AWD or RWD
EDIT
not sure if its finished but heres a sample if u like i will probably leave it
Edited by Madaz
Yes accidents can happen anywhere any time, that was pretty well the point being made.
No I don't think everyone drives an unrelyable skyline, but you never know what could go wrong. As the saying goes 'shit happens'. I'm personally very confident in my own ride 'touch wood' as it is well maintained. However I'm not going to proclaim it unstoppable, just like the Titanic was unsinkable......
I think if everyone as a group could bring a few spare parts (say 1 person brought their spare wheels, another a spare crank angle sensor, another spare coils etc) to cover everybody for the common issues known with skylines it may save someone the agony & expense of having to have their car towed back if necessary.
Also the other point is to make sure your car has been serviced & any known problems that have come up be fixed. A car is made up of thousands of parts, but it only takes 1 for you to be left stuck on the side of the road.
I don't think it's likely that something would go wrong, but you never know, prevention it better than cure.
Edited by JazzaR33
yeah its normally the $2 part that fails
Hmmm I'm guessing accomodation will want to be cheap, so tents would be a goer, but then it's a matter of preference. I'm thinking I should set up a poll for this stuff.
I don't even have a fishing rod myself. But then I do love fish so maybe I'll have to make a point of getting one, mmmmm BBQ seafood.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
