i was thinking of going....
anyone know if its on and anyone else plan on going?
Yes, it's on tomorrow (weather permitting of course)
quick question...what if the car is not registered in you name? what sort of identification or letters are required?
Everything you need to know is on this webpage (taken from Wed Street meets, but same rules apply for Friday)
Good luck :(
yeah i'll be there trying to improve my 60ft's, and race my mates wrx FINALLY hahaha...
hopefully get him off the mark because his too scared of destroying his gearbox and granny shifting.
i'll say hi if i see your SERIES 3 GTR there hahaha
ill be there...got some used semi slicks to get use to and to get my time quicker...cant wait to have a look at ur GTR....if you dont mind me haveing a look. what mods do u have and power and est et?
It was an awesome night in terms of weather and turnout. It was a shame that i couldnt get to see all the other cars race. (congrats to 1jz747 on what looks like a personal best) Thanks shortie for the tyre pressure gauge, someone could of told me that i had to clear the memory function before i let one of my rear wheels down to 3psi bwahah.
HKS GT-SS Turbos
HKS dual Dump and Exhaust system
HKS air pods
HKS intercooler
Tomei Poncams/Gears
Sard 700cc Injectors, rail, and reg
Nismo Fuel pump, intank
Splitfire coils
Power FC and AVCR
Power output is 340rwkw @ 8,000rpm @ 1.5 bar BP ultimate fuel
Last night ran with 370rwkw on a race tune :rofl:
Edited by HKS26T
HKS GT-SS Turbos
HKS air pods
HKS intercooler
Tomei Poncams/Gears
Splitfire coils
Power FC and AVCR
Last night ran with 370rwkw on a race tune :O
Congrats mate, What was your 60ft and mph? Good to see mate! :)
Congrats on an awesome time HKS26T, was that with a stock motor? Who is your tuner? I think you've convinced me to go buy a 33 gtr lol
First time racing at the strip? I'm surprized they did'nt tell you to go home as soon as you got into the 11's let alone 10's.
Edited by bmxwrx
Thanks mate. The Bottom end includes forged pistons, standard rods, head gasket etc. My tuners are Dave Haak (by appointment) and Adam Neish @ JEM. It was the first time for the car at the creek. The officials were great.... i think it was aaron i spoke to...he asked me to turn down the boost a little and i could go back out :mellow:
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
