Got some of these gauges for sale:
Smoke series gauges from $39, also have water temp, oil temp, oil pressure, vacuum, volt, ait/fuel ratio gauges and 360 degrees boost gauge, all prices are different.
-Auto Gauge 270 degrees 52mm Boost Gauge(PSI) $39
-Auto Gauge 270 degrees 52mm Boost Gauge(BAR) $39
EL series gauges from $29, also have water temp, oil temp, oil pressure, vacuum and volt, all prices are different.
-Auto Gauge EL 270 degrees 52mm Boost Gauge(PSI) $29
-Auto Gauge EL 270 degrees 52mm Boost Gauge(BAR) $29
Auto Gauge gauge holder to fit all kind of gauges from $13, please leave part number.
Autogauge turbo timer
-Auto Gauge Mini Box Style Auto Turbo Timer $47
-Auto Gauge Pen Style Turbo Timer with Voltage Display $55
*All new in box, come with all necessary hardwares and English installation manual.
*Please try not to PM me unless something personal, just leave a message in this post if you're asking for price or question, I'll get back to you asap, so I can keep this post update, thanks. :(
Edited by cookiebear
  • Replies 61
All PM replyed, and if you've any question please leave it here, and I really perfer not to PM me, I rather answer everyone's questions in here, unless something private, otherwise my post can be lost in 1 day, thanks. :(
  • 4 weeks later...
wraith_skyline, for the smoke series boost gauges, you can get them in bar or psi, they're $39 each + postage, and I have another smoke one which is a 360 degree boost gauge (psi) for $65, same as the one you see in the photo.
lineskee 33, still have your number and all your details, will keep you update when the money arrive, thanks for buying. :)
Hey mate,
have you got anymore of those Smoke series boost gauges $39. i assume its the one in the first attached pic? just a question..how much do they read up to? i assume 30psi? and for anyone who have used them before...... are they accurate?
kind regards,
Edited by R33LIN
ODessA, if you're buying them together, they're $90 + postage, usually oil pressure is $34, oil temp is $34 and water temp is $31, you save $9. If you're getting the gauge holder as well, I can give a a better price too. Let me know soon, thanks.
R33LIN, it reads up to 30psi, and I still have them for sale. Where are you from?
how much for a smoked series oil temp and a smoked series afr together posted to Northgate, SA, 5085? Cheers, Andrew
Nightcrawler, oil temp $48, air/fuel ratio $61, I can get both send out to you for $110, usually $5 postage per gauge interstate, may be cheaper for same state. Let me know soon, I can get them to you by tomorrow. My number is 0402 452 455, message/ring me if you're interest, thanks.
Nightcrawler, not really, even the EL series oil temp is $35, prices are just depend on what gauge it is, and the smoke series air/fuel ratio gauge is the second most expensive gauge I have. Anyway, let me know if you change your mind, usually people get more discount when they order 3 gauges/items more, so $110 posted to you is not really bad. Anyway, let me know soon. :teehee:
ODessA, didn't know if you get my sms, but I'll keep an eye on my account and I'll update you with sms again when I get the money also when I send the item, thanks for buying. :P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
