  • Replies 41
If you can find a good condition rotor that is!
Go the 34! If your not out to be a track hack, 34 is great for daily driving. However, NO STICKERS PLEASE! :)
Punks will target your car more and it doesn't add horsepower, engine mods add power. :)
WTF? no more unconfirmed comments like these please..... :)
i cant imagine a r34 4 door would be more expensive than a two door, maybe they will be harder to find in as good nick as that black one.
its a worry.....
Ninjadust, it might be worth having a look at www.racecoursemotors.com.au they are advertising an r34gtt for less than $30k (fairly high kms though).I'm not sure how much confidence you have in odo resdings on imports, but I usually pretty much ignore them and use overall cond as more of a guide. (Some cars seem pretty rough for very low annual milage)
That is a nice black GTT. I have a soft spot for black cars cause they come up like showroom finish after you take it to the carwash. I had a yellow GTT R34 with the exact same body kit (C-West) and that made a big difference to how nice it looks. That is a genuine C-West from what I can tell and it cost me like $8k to get it supply, fitted and painted.
I say Buy iT!!! Its a great daily drive and you will get attention. Your little boy will love it too as it gives him a bit of a rush when you give it a hit. He'll be saying, "Daddy, go faster, my tummy tickles" hahah. Well, that's what my nephew said to me anyway, but uncle instead of daddy...small point of clarification there. ;)
I've seen the white GTT in the flesh at RCM. Very nice indeed and well priced. Pity it's a tiptronic though, very boring to drive. But if that's what you're after, it's a bargain. There's also a totally stock purple R33 GTR in the shop for about $38-$40k. I drove that one and she screams. Interior is excellent, paintwork is very good but may need touchup if fussy. Needs new tyres and alignment, but otherwise, there's nothing that needs to be done.
yo, if you like the car and obviously you do then well hey buy it! thats what i reckon, however the rear spolier is a bit bad you should change that. money is there to be spent as long as it wont leave you sleeping in the streets in your new r34 and eating out of dust bins then buyy the byuetch.! my 0.02
Big link, hope it works.
Nice R34 4door.
http://www.carsales.com.au/pls/carsales/!cs_results.display_vehicle?dweb_id=&vehicle_id=1185045&instant_flag=&service_id=21&total_rec=38&current_rec=21&multi_flag=0&order_by=photo_avail+%3Asort_order%2C+vehicle_id+desc&sort_type=DESC&make_id=5&model_id=73&region_id=104
  • 11 months later...
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
