the fcon sz pro i think it is, is pretty good, much like most of the hks ecu stuff but the problem is there are no local tuners, so you need to be in sydney and you only have like 1 or 2 tuners so they can charge you any price and give you any level of service they wish and you have no choice, you cant just walk away and go see someone else.
if there were lots of hks tuners in australia, sure go for it, but dont bother in australia, unless u have unlimited money, then if you do buy motec
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2699990
Not entirely true about the pricing... but I guess your concern Paul is very valid (per case application I guess)
I've had my car tuned twice now with the F-CON and both times the pricing has been extremely competitive when compared to elsewhere.
PM me if you want definite prices; think your mind might change afterwards.
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2700006
They're one of the only places I know of that guarantees their tuning... if anything stuffs up they tune it back for you without question.
But true, the towing from interstate if a problem occured would be a nightmare.
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2700086
"I've had my car tuned twice now with the F-CON and both times the pricing has been extremely competitive when compared to elsewhere"
were did you get this done what sort of tune did you get
i.e full tune or tidy up of a jap tune?
Ive been told that BD4's can not tune f-cons and they have a capboard full of ones they've removed from cars
I love to have been told the wrong info as my bosses gtr has one fitted and another 2 tough jap cars I know of have one fitted aswell
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2701668
Whoever has told you that BD4s cannot tune the F-CONs is full of it... they are the ONLY people in AUS who can and will tune the F-CONs.
You need to be a registered HKS Pro Dealer to even have the Power Writer software and BD4s is one of them.
Thomas Lee is their tuner and he knows his stuff... definitely worth giving him a call and talking to him. He'll give you his time as well unlike many other places who hurry to finish the calls.
What type of tune did I get? Well the F-CON V Pro came off a R34GTR so the tune was not compatible (not that I would have used it anyway) so I needed it tuned from nothing. Unlike the PFC there is no "base map" everything needs to be done from scratch.
My second tune was when I installed injectors etc etc... Most tuners would just modify their existing map - Tom did it from scratch again.
Both tunes lasted about 10hours each, and each time I've paid what most would expect to pay for a full PFC tune which I've seen done in even 1/3 of the time.
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2702573
Not going to start another debate about how good/bad F-CONs are but consider why most high HP cars from Japan use it over the PFC... also consider why a seemingly "piggyback" system would be preferred over a "standalone" ECU.
I was sceptical to start off with too... but after talking to Tom, seeing it done, and driving my car - I'm converted. Talk to silver r32gtst from here, he's running one too.
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2702577
I was previously using the fconv but am now using a power fc pro...
to me the flexibility of being able to choose my tuner is a big advantage...
i personally did not have a good experience with bd4s and would not go there again... although im sure other people are more than happy with thier service...
additional costs with the fcon are getting it wired in which has to be factored in as well
just some thoughts
https://www.sau.com.au/forums/topic/144512-hks-pfc-con/#findComment-2702591
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
