hi guys,
needs some help fining an engine for my C210.
The motor stopped on me yesterday, and was about to take the plates back to the RTA, and chuck the thing, but for some reason really don't want to get rid of it. My current motor has really had it, was barely starting as it was, and I'm looking to make the thing as realiable as possible for a 30yr old car.
I've spoken to a few places this morning for a full recondition and I'm looking at over $1500.
So if anyone know's of a working motor - L24, L26 or L28 in Sydney, please let me know.
The car is a 78 Coupe, auto, but will do a manual conversion now as well.
thanks
hi mate,
i am not sure if it is helpfull, but i have most of an L24 that you can have. I am not sure about it's condition (it has been covered in plastic, but outside for the last 2 years.. i also have a 5 speed manual you can have.
again, i have to stress, i have no idea what good these are., they came with a shell i bought. but you are more than welcome to them if you want to pick them up. i think they were originally from z's
pm me if your interested..
hi mate,
Hey Kent,
If they are from a Z, what head is on the block, E30, E31, E88, or N42?
Nick.
Thanks for the replies guys.
Car is back up and running, cost me an arm and a leg in parts. All up $1.50 for 1 resistor :-)
Was ready to take plates back to the RTA, but couldn't part with the car. I think I'm nuts, but I really enjoy driving this thing. :-)
Hey Guys,
I might be able to get my hands on an L26, with 5sp manual out of a Z, which was apparantly reconditioned only 20000k's ago. My understanding is that this would be a straight bolt in job.
Is it worth the hassle to swap out my L24 in the C210 for this? I've currently got an auto, but can get my hands on a gearbox quite easily, so the big issue is the motor.
What would you pay for an L26 motor and 5sp?
Cheers
hi mate i got a r30 skyline and thought about puttin an l26 in it but thought nothin gunna beat cubic inches
if u want more go. go the bigger l28 engine
ezy bolt in and it will run your carbies exhust to
all u have to do is put your sump and oil pick up in it
cheers
Edited by REDNECK
If your L24/box is on it's way out, and it's the right price, is really is nice and fresh, and has well sorted twin carbies I'd really consider the L26; better head with bigger valves and pick of the cams, you can keep virtually everything off your L24 as a spare and its much better to do the box and block as a unit rather than seperately. Not to mention the relative ease of bolting it in. An L26 into a C210 was my first and only engine swap and I managed to do 99% of it solo, and Im known to be a truely crappy mechanic. You can save your cash for other bits... unless of course someone has a really sweet L28 for you, in which case I entirely agree with everything Mr Neck said above.
What's the deal with the L28's from a patrol?
are all variants good for an upgrade? are they set up different to the L28's from a Z? and would anything need to be changed on the engine if I'm putting it on a c210?
thanks
i wouldnt bother with an l28 out of a patrol i thought they were 4wd and had front mounted something a rather opposed to the 280zx l28 but im not too sure on what exactly needs doing but more work then worth it i was told when i was thinking about it
cheers paul.
IIRC, the Zs have the bowl of the sump in the middle, while the C210 / Skylines have the bowl near the front.
This may be the advantage of using the Patrol L28 over the 280Z L28.
hey guys for an l28 swap in to a c210 is put your sump and pick up on it
every thing else external is the same if u got an electronic dizzy chuck thet in and with a well tuned set of carbies u'll be tearing the tar up in no time
cheers
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
