Comes with one boot only. You only replace the one thats damaged, commonly the outer as it does much more work.
The boot kit is either:
39241-05U25 or
39241-05U26
I cant work out what the difference is as the text is all jumbled. Hope that helped
Just take the slip pins to a place like autobarn and get a pack that matches them closely, its not that important they are the exact same size but try to get them close.
https://www.sau.com.au/forums/topic/144716-cv-boot/page/2/#findComment-2715180
Hit end on from where i have indicated with red arrows. This is the potentially tricky bit as the clip on the splined joint are known to get stuck and not let you remove the cv joint...
Make sure you only hit on the part i showed you can do damage otherwise. If you get a better photo of the inside of the joint i will show you more accurately where to hit.
Deren
https://www.sau.com.au/forums/topic/144716-cv-boot/page/2/#findComment-2723167
Hey I know a temporary fix if ya want to get the car somewhere that involves some traveling , and it involves a plastic bag and race tape.
I broke a boot on my subaru and just wrapped it with a thick type of plastic bag and taped the ends so that it covered the joint and kept dirt out and what ever grease left, in. I was surprised how long it lasted too.
https://www.sau.com.au/forums/topic/144716-cv-boot/page/2/#findComment-2723201
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
