Hey guys, for those who have tried and tested. Is there much to be gained over the original R32 GTR sway bars with say whiteline uprated bars? If there is i may choose to replace them in my rebuild.
If i do choose to swap to aftermarket are the GTR bars any good to the GTS-t owners out there? If they are feel free to make an offer.
Deren
https://www.sau.com.au/forums/topic/144766-r32-gtr-sway-bars/
Rear bar will fit GTS-t but front wont as the front subframes are different (you have a front diff). The aftermarket whiteline swaybars are solid and considerably stiffer because of it (24mm rear is 147% stiffer than stock)
You also get the added bonus of having adjustment in the swaybars to adjust to the handling balance you prefer.
Ok thanks for the help mate, i appreciate it! So you suggest replacing both front and rear? Do you know what they are worth? Best place to buy them from?
Anyone want a GTR rear sway bar? Hehe, its already detailed up in satin black.
Groupbuy
And yes, replace both front and rear otherwise it will not be balanced. Only having front bar will make it understeery and only having rear bar will make it oversteery.
Edited by salad
It is true that hollow bars are much more efficient at handling torsional loads and therefore you can save 5-10kg from them. But they are much more expensive as hollow spring steal is not cheap, the range of sizes is limited and it is harder to mandrel bend (more expensive machinery is needed)
id like more info to but why would you need to mandrel bend them anyway?
sowhat is a better upgrade for a r32 gtst a GTR standard one or a whiteline?
If not mandrel bent, the cross section across the bar is not uniform and therefore stiffer in some sections than others.
The better upgrade depends on what spring and shock rates you are running. GTR rear swaybar is indeed a good value for money upgrade, but it is no where near as stiff as the aftermarket whiteline ones available.
22mm swaybar is 74% stiffer and 24mm is 147% stiffer. With the Whiteline bars you also get the added bonus (if you choose so) of adjustability.
By my rough calculation a solid 25mm anti roll bar is less than twice as stiff as one with a 2.5mm wall thickness.
Or to put it another way a 30mm od bar with a 2.5mm wall will do the same job as a solid 25mm bar for less than half the weight.
Edited by djr81
cusco do them for 32 GTR. justinfox has the cusco ones. ARC do them too. I'm sure there are others.
Not that I have seen.
Hollow stabiliser bars are horrendously expensive to make.
A few poeple have claimed to have aftermarket hollow stabilisr bars on their Skylines.
But when I check they are either solid bars or simply painted standard bars.
:pirate: cheers :kiss:
Not quite.
A 25mm solid bar is 191% stiffer than 25mm hollow with 2.5mm wall thickness, so almost 3 times as stiff
The 25mm solid bar is still 64% stiffer than 30mm hollow but the hollow is 23% of the weight. One way to have the same stiffness as a solid 25mm bar is to have 33mm OD with 3.2mm wall thickness. This bar will be 32% of the weight of the 25mm solid. There are endless combinations of OD and thickness that you can go through to make the same stiffness though.
Edited by salad
All this is very interesting. So should i just stick with my hollow genuine items cuz they are lighter etc? Will the dampers/springs be ok as the only mod to inhibit body roll? It impresses me when i find out things like the hollow bars etc on the GTR are standard. It was a damn fine car for its day, not to mention now!
Deren
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
