does anyone know how to remove the rear seats?
Remove the 2 bolts at the front of the bottom section of the seat and it will come out .. revealing the 2 bolts at the bottom of the back section .. take these bolts out them pull forward a little at the bottom and force the seat up (sometimes can be a little difficult), the whole process should take 10 minutes.
As for the factory immoboliser ... doesn't have 1 standard to my knowledge
you will need aftermarket for the 3 point insurance requirements
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2704158
If you need a immobilier try one of these......they stop anyone
But anyway,
Na the stock one isnt complient for what you need as it isnt 3 point and isnt all black wiring. i highly recommend getting a aftermarket one like a autowatch
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2704211
Garry is right, they dont have one at all...
Mongoose also make a 3 point immobiliser with black wiring. M80 series.
The M80 would be my first choice for value...
I persoanlly run the M60S as it offeres battery backup and auto window up and is compatible with all turbo timers, which is perfect for turbo's.
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2707997
M80 is a triple immobiliser, whereas the M60 is only a dual immobiliser, so the M80 would be the immobiliser of choice if your insurance company requires a triple (or 3 point) immobiliser system. The M80 series offers the features of the M60, plus more.
The M80 is compatible with Shannons Insurance requirements due to the triple protection of the immobiliser.
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2708123
I would have to agree. The m80 is a good reliable immobiliser/alarm. go to autobarn at Slacks Ck. Not only do they know there shit, they also know skylines. i talked to one of the install dudes and he was able to say what i needed, what i didnt need, etc. Would recommend both the m80 for both insurance and piece of mind and Autobarn at Slacks Ck
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2718234
whats the m80 worth and how much to fit?? anyone know?
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2718526
Hi Guys,
M80 is the way to go! It has the three point immobliser, If you twist my arm I might be albe to through in a window lift module.
We have other alarms to but from my expeince mongoose are the best, If you want to be in contact with your car all the time, they even offer the SMS module.
If you have any Questions feel free to give us a call -07 54 9333 66
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2718920
Well Matt the M60S set me back about $280 and it was a DIY job for an me, but then again im a qualified auto-elec... :pirate:
The reason I suggested the M60 in the first place was price... The M80 is superior hence why the model number is higher, but most insurance companies only require you to have 2 points protected and in this case money is Matt's issue so the M60 would be his best bet....
Seriouslly hit up Chris Rogers for a installed price as he will be your best bet being a club sponcer...
Better yet you can talk directlly to Sam and Chris this Sunday at the SCC... :kiss:
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2720324
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
