  • Replies 103
Guest INASNT
Originally posted by rev210
I found out I'm not to blame for being an idiot self tuner.
The problem (knock/ping) seems to be a single piston issue. We suspect a blocked injector or two. The afr's are super rich as I have previously dialed in more fuel to cushion any potential damage.
The result was a ping at about 4700rpm that prevented us reving it any higher.power: 230 rwhp - afr : high 9 with very little timing advance
170odd rwkw with 9 a/f ratio?? so ur car is a freak then!:D
Dave,
230rwhp (172rwkw) @ 4700 is bloody impressive! Given that peak power isn't till 6800 stock. If you've dialed the HKS cam gear for more top end then the peak might be even higher?
My estimate of mid 190rwkw is lookin' good :mad: It might go even higher!? Especially when you're running conservative timing & nasty rich.
While on the A/FR's, 9:1 isn't very healthy @ all :) You might have dialed in a little too much cushioning! Not quite as bad as too lean, but still not good.
Originally posted by INASNT
170odd rwkw with 9 a/f ratio?? so ur car is a freak then!:mad:
Yepp, just as we thought, Rev's got one of those freak 1995 cars :uh-huh:
It's good to see that the ping issue 'shouldn't' be anything major.
Are you getting them cleaned using the ultrasonic bath way?
Once you get the ping sorted, and back for a re-tune, I reckon you'll see your 12 second pass :uh-huh:
Well done
J
It's not a freak car.
The first dyno it ever had (over 2 years ago) showed 180 rwhp odd on a dyno day with other cars and whilst a heathly figure it wasn't the highest.
the mods and tuning I've done are responsible for the power and considerable torque it's making (afr's uptop aside).
Mine's a 95, but it's no freak, hell I can't even pull the 1/4 in less than a 14 right now... so bleh!
considering dave ran a 13.4 without the AFC, i still cant see what i'm doing wrong...bleh!
Originally posted by EnricoPalazzo
So let me get this rite? 170rwkws at 4800RPM????
DAIM.
Pretty respectable figures considering engine mods are turbo back exhaust, panel filter, thermal wrap, 10psi, cam gear, afr of high 9's (untuned s-afc), and a little advanced timing (did I leave anything out?).
I'd be happy with that, that's for sure :D
Most people get less than that with a 'professional tune' at a workshop :)
Rev - are you getting the injectors clean by an ultrasonic bath?
Cheers
J
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
