So i got my car tuned today with these 'mods':
Apexi SAFC2
Apexi SITC
Greddy Profec B S2
3" exhaust dump pipe back
Filter
BOV
Came back with 169.8rwkw. Not sure whether to be pleased or not. I think its okay. Perhaps a FMIC would net a bit of gain.
Tune seems to be rather safe at around 11.5 A/F ratios on 11ish psi boost.
It feels wierd to drive, seems to have a fair bit of the original dip at 4500-5000rpm, maybe its just the fact that power picks up quite sharply after 5500rpm.
Heres the printout for ya, a bit nasty as its a phone camera shot. Red is original/base tune at 6.5 psi peak, Blue is final tune.
Boost seems to fall off after 5500rpm, so highflow turbo/front mount may be the next items on the agenda.
Damn money pits these cars!
https://www.sau.com.au/forums/topic/144947-got-dynoed-s2-rwd/
170 rwkw from an exhaust, boost up and piggy back tune is pretty damn good. I can't read the graph all that well, a decent scan would be nice. In particular would like a closer look at the boost and A/F ratios graphs.
Is the exhaust turbo back? If so, is it split dump? High flow cat?
Want to share the SITC settings? I will be interesting to compare the S2 with an S1.
:teehee: cheers :laugh:
hey. Ill try and get a better scan some time. the AF on the final tune is aroun 11.5 and goes down to 11 at just over 5500 rpm.
Boost is on the 11psi line to give you an idea.
My SITC settings are:
0, +2, -2, -1, -1
SAFC are:
4000: +2
4500: +2
5000: -3
5500: -6
6000: -10
6500: -14
Mind sharing yours as well. Id be very keen to know.
It appears the AF ratio is now safer than before below 5000rpm.
Exhaust is 3" dump pipe back with not cat, 2x resonators and a semi straight through muffler.
Edited by GorGasm
0, +2, -2, -1, -1
SAFC are:
4000: +2
4500: +2
5000: -3
5500: -6
6000: -10
6500: -14
I don't have an SAFC, I am using a DFA, so unfortunately those setting don't correspond. I have as flat an A/F ratio as I can manage at 12.0 to 1 from 3,000 rpm to 7,200 rpm. I made sure it was never leaner than 12 to 1, so it hasa couple of spots where it gets into the high 11’s. But that the compromise you make when using a piggy back.
On the SITC I am running;
800rpm = 0
2,400rpm = +5
4,000rpm = -1
5,600rpm = -8
7,200 rpm = -12
So it looks like I have a fair bit more aggression in the ignition timing. I am using Shell V Power Racing 100 ron, which might be why I can run a bit more advance. I have tuned it using a set of bionic ears and listening for knock.
I have been road tuning it so far, so I haven’t had it on the dyno. I will do that once I have fitted the last mod, which is a Performance Metalcraft split dump engine pipe combo.
I do have a very lightly used GCG Ball Bearing high flow on the shelf that I was going to put on, but I like the low down torque that it now has. It is very useful when towing the R32GTST, which, after all, is what the Stagea is supposed to be used for. So I might keep the standard turbo on until it gets ceramic in the cat disease.
On your no power problem at 4,500 rpm, I am surprised that the SAFC is set at +2. That means the ECU is seeing more than normal airflow (ie; higher voltage). So you have actual higher airflow from the higher boost and lower restrictions (exhaust, filter etc) and then the SAFC is adding to that. The ECU should be jumping to R&R mapping, which would explain the loss of power.
Once you start lowering the AFM voltage (that the ECU sees) from 5,000 rpm onwards, the ECU is far less likely to jump to R&R mapping. More voltage correction from the SAFC as the rpm rises means you get further and further away from the trigger.
I have found that the 4,000 rpm to 5,500 rpm range is always the hardest to tune using piggy backs. It is where the most compromises have to be made in the A/F ratios and ignition tuning. Under and over that range is far simpler in comparison.
:laugh: cheers :wave:
PS; if you want to test this out yourself, try changing the SAFC setting at 4,500 rpm to 0 or even -2. Then do a quick run and see if the power loss is still as severe. I wouldn't leave it there, but a couple of short test runs won't hurt. Then you will know what direction to head in when you talk to the dyno tuner.
Nice info there.
As a comparison, thought Id check my figures.
On the SITC I have
800rpm = 0
2,400rpm = +1
4,000rpm = +3
5,600rpm = +4
7,200 rpm = +4
very very different to the other settings mentioned.
How do I get my safc settings? Played with it a little but not sure what Im doing :D
just monitor 4channel, and use throttle to see the different rpm figures?
Nice info there.
On the SITC I have
800rpm = 0
2,400rpm = +1
4,000rpm = +3
5,600rpm = +4
7,200 rpm = +4
If I remember rightly, you're not running a standard turbo. So I wouldn't expect the ignition timing to be same.
:huh: Cheers :kiss:
Hey SK would you mind posting you DFA maps if you have a second? It would be an awesome reference.
I too was quite suprised to see more air dialed in at 4-4.5k. I was running around on my road tune with about -6 set on the safc at these rpm and it felt MUCH better. I did hear a bit of det with anything higher than 0 on the timing with this setting though so i guess it may be getting quite borderline.
I haqve already changed the settings that the tuner gave to:
0, +2, 0, -1, -1
SAFC are:
4000: +2
4500: -1
5000: -5
5500: -7
6000: -10
6500: -14
I think i will dial back 4500 and 4000 a bit more in the coming days and put my good ears on to see how it goes. I may also throw it on another dyno if a dyno day comes around.
Kinda annoyed that i spent $340 and still had the monster boooobaaa R&R thing happening.
Tangles:
To check your safc settings hit the back button until you reach the main menu where you can select monitor/settings/etc. Select settings then select Hi-throttle. Then just browse over the different points to see what the settings are.
Now when im rich i think ill go for a highflow, split dump and FMIC.
Cheers.
LR
Heres a question.
My stock ECU takes 13-15psi without hitting R&R, but some of my friends said theyve heard a bit of pinging when on full boost/high load (140km/h etc etc)
When I check my injector duty on my IEBC, it doesnt go over 54-55 out of 64, the question is, if my injectors arnt maxing out (which I assume is load point 64) can I still get heavy knocking with a stock ECU?
13psi
full non split exhaust, 3 inch, very flowy
GCG high flow
TRUST (SK :P) GTR FMIC
El cheapo POD
:) Cheers ;)
Nah, thats the settings from the 160awkw @ 12psi tune on the standard turbo.
Only changed to the highflow mid last week, and wont be getting a tune for another month at least.
Umm, by memory boost didnt trail off for my Stagea (using a dual stage Hybrid EBC) .... although I never had much time over 5000rpm (never saw the point), however the RPM rise thru to redline was reasonably fast.
Now with the highflow turbo on (untuned) I still havent noticed any boost drop but I have noticed that the RPM ramps up from 4000 - past 6500 very very quickly.
fun :P
cheers mate, will post up the safc specs asap
I got 170rwkw (awd stagea on 2wd dyno) at 9psi (cheap manual boost controller jumps up to 11psi and slowly works back to 9psi at the top end).
Mods:
- 3" turbo-back exhaust (incl 3" hi-flow cat and 2 straight thru magnaflow mufflers)
- gt30 turbo
- safc
- manual boost controller
- apexi panel air filter
There was no dip in power at all on mine, and the revs do build very fast right from the get-go...just gets faster and faster as the turbo comes into its "sweet spot" above 4000rpm...
Definitely needs more boost and the turbo will handle it fine, I just need to save for a sitc and upgraded fuel system bits and a good tune, and probably a good EBC while I'm at it.
I reckon I could squeeze a bit more out of it in its current state (not sure if my manual boost controller is set up correctly) but not worth the money for another tune.
Sounds like you're enjoying your new turbo Brendan? :P
Let us know the results when you get it tuned next :wave:
loving the turbo for sure :ermm: need to save for an oil cooler kit and a 3hr tune.
Safc settings, on hi-throttle are:
1000 rpm + 21%
1600 rpm + 29%
2200 rpm + 44%
2800 rpm + 46%
3400 rpm + 49%
4000 rpm + 49%
4600 rpm + 46%
5200 rpm + 36%
5800 rpm + 38%
6400 rpm + 35%
7000 rpm + 35%
7600 rpm + 35%
Safc settings, on lo-throttle are:
1000 rpm + 1%
1600 rpm + 21%
2200 rpm + 26%
2800 rpm + 31%
3400 rpm + 42%
4000 rpm + 44%
4600 rpm + 46%
5200 rpm + 47%
5800 rpm + 45%
6400 rpm + 44%
7000 rpm + 42%
7600 rpm + 42%
Th-point settings are:
Lo 19%
Hi 20%
Hope that helps ?
Meh, good for my future refence anyway. "Tangles safc settings" will be my search :laugh:
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
