sorry fellas, been a bit busy (plus an impromptu christmas vacation inbetween). will post em out tomorrow.
gonna also put the order in for the next batch.
  • Replies 180
so those of you who want some (and aren't part of the batch that's being sent out)... please post what you want...
hard one... there's like 5 issues for the legacy wagon...
I'd probably get Vol.88, but then I don't have one, nor do I know much about em.
Could you please put me down for volume 88 please Shan ? :yes:
Shan, are mine (the Stagea ones) in this current batch or will they be in the next one? Please let me know so I can organise payment soon. Will be away till Sunday, but can send payment after that...
Thanks
Nick you'll be in the next one (which I'm gettin done today :P). I prepay for these anyways, and then collect payments... seems to work so far :mad:
Could you please put me down for volume 88 please Shan ? :P
If you've got a 95, I think you've got a BG series Legacy... in which case it'd be Vol 24 or Vol 40 that'd be more relevant to you (going by the brief content listing on the covers):
There's also these hyperrevs:
and these:
Subaru Legacy - All generations, specs, maintenance, testing and customisation
Subaru Legacy Wagon - Style RV Special Edition
Thanks for the update Shan, i'll purchase volume 24. Thanks. :happy:
Could you please pm your bank details ?
Edited by SNISMO
Nick you'll be in the next one (which I'm gettin done today :)). I prepay for these anyways, and then collect payments... seems to work so far :huh:
Cheers, mate. i will wait for your PM.
just placed the order for the second batch.... two packages with over $1000 in books lol.
my credit card's feelin the pain.
Shan, are you able to get Dress Up D Car magazines ?
Dress Up Car Magazine sorta went dead after June this year, and hasn't had any new issues... as such they're sold out across newsagents and they're not that easy to get at the local newsagent.
Check http://www.dressup-car.com for back issues though... might be able to get em if they're still available.
lol the mag's full of rice that's copied from the US anyways, just like Hot4's :wave:
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
