Hey guys and gals, I would rather get rid of these seats in Canberra. Have 2 x Autotecnica black and grey seats, with shoulder harness gaps.
Both seats have small scratching from installation attempt, however seats work fine and could be fixed with a small amount of silver paint. Never been fitted to a vehicle.
PM with your mobile number to receive pics or inspect at my place.
Retail for approx $450 per seat, Im selling for $350 for a pair.
I can deliver in Canberra or surrounding areas, but pick up for interstate.
Edited by datto260Z
https://www.sau.com.au/forums/topic/144959-fs-autotecnica-seats/
An obvious question, can you use std rails, a 9", a welder and make your own. Do a good job, nothing bodgy/dodgy.
I would guess it would be illegal, but it is just mild steel, they aren't made out of chrome moly. I've often looked and thought it would be an easy task, day to fit, day to powdercoat/paint.
A good job would be hard to pick!
Yeah, thats what I thought, but when you look at the mounts [either the seat mounts or the floor mounts, depending on which rails you have] it wouldn't be a big job.
I reckon I could do it in a couple of hours really.
This would make datto's seats a real bargain [and they look excellent as well].
Sorry for the OT datto.........GL with the sale.
Hey mate, as long as the person welding knows what they are doing it would just have to pass engineering. On the other hand, if you can modify your stock rails to fit, then it would either not need to pass engineering or pass engineering easy as.
John Wilson did my engineering for my car, so he is the man to look up and ask.
These seats are the bargain of a life time, I just need the money and garage space. The scratches could be gone over with a spray can.
  • 2 months later...
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
