my playlist for the next half hour or so:
Chasing Cars - Snow Patrol
How To Save A Life - The Fray
It's Too Late (Dirty South Remix) - Evermore
Running - Evermore
Light Surrounding You - Evermore
Joker And The Thief - Wolfmother
Woman - Wolfmother
put down what you are listening to at the moment
and this thread will prob die on its ass in teh next day
so post away
Edited by 342Four
https://www.sau.com.au/forums/topic/144992-what-are-you-listening-to-right-now/
  • Replies 612
Running - Evermore
Woman - Wolfmother
so post away
Got emo?
Im listening to an old guy tell me about his problems with Windows 98 1st edition and how he wishes we still had Windows 3.11..
Its like music..well like dance music really.. he keeps repeating the same thing about.. ohhhh I don't know 15 times!!!
:laugh:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
