my playlist for the next half hour or so:
Chasing Cars - Snow Patrol
How To Save A Life - The Fray
It's Too Late (Dirty South Remix) - Evermore
Running - Evermore
Light Surrounding You - Evermore
Joker And The Thief - Wolfmother
Woman - Wolfmother
put down what you are listening to at the moment
and this thread will prob die on its ass in teh next day
so post away
Edited by 342Four
https://www.sau.com.au/forums/topic/144992-what-are-you-listening-to-right-now/
  • Replies 612
Running - Evermore
Woman - Wolfmother
so post away
Got emo?
Im listening to an old guy tell me about his problems with Windows 98 1st edition and how he wishes we still had Windows 3.11..
Its like music..well like dance music really.. he keeps repeating the same thing about.. ohhhh I don't know 15 times!!!
:laugh:
