  • Replies 612
does cypress hill do a song in GTA:San An
goes like:
'if i could just kill a man...
here is something you cant understand, how i could just kill a man'
EDIT: think i found it
rage against the machine ft cypress hill: how i could just kill a man
EDIT EDIT:
better version
cypress hill: how i could just kill a man (official clip)
http://www.youtube.com/watch?v=d12EI3xNiqE
Edited by 342Four
^ if you can get a copy of the rage against the machine covers album "renegades" there is a bonus track on it with RATM and Cypress hill doing that song together live on stage and it ROCKS!
Royksopp - Only this moment
http://www.youtube.com/watch?v=ST2BGQWeOgY
With lyrics!
Okay..
Only this (moment)
Holds us (together)
Close to (perfection)
Nothing else (out there)
No one to (guide us)
Lost in the (senses)
Deep down inside I know our love will die
Okay..
Only this (moment)
Holds us (together)
Lost in (confusion)
Feelings are (out there)
Scared of the (ocean)
Doubting (intentions)
Stay or forever go
Play or you’ll never know
We haven’t decided
You can’t deny it’s all you’ve been waiting for
Okay..
Stay or forever go
Your spirit’s divided
You will decide if I’m all you'll be waiting for
Guilt in my head
Have Been part of my twist
By the force of an angel
Revealing our fates
And our words don’t make sense and I do understand,
Falling in love isn’t part of our plan
Forces within me, makes reason with lust
But I try to accept it and not think it works
'Cause I know I might lose you by taking a chance
But love without pain isn’t really romance
Okay..
Only this (moment)
Holds us (together)
Always (beside her)
Trusting my (senses)
Deep down inside I know i will survive
Only this (moment)
Holds us (together)
Always (beside her)
Trusting (my senses)
Deep down inside I know I will survive
Okay..
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
