today after work i arrive home a happy chap all excited about my r33 which i'll b pikn up in the next 3 weeks when my dad say's guess wot? I say "umm i broke the gate" he says no worse.... you cant get the r33 because full comp insurance was 5k CHEAPEST!
He just refuses to get a car without full comp which i think is bullsh*t!
He said we can look at a nice VS calais for the same price (16k) but it compares like chalk and cheese.
So now i feel like crawling in a hole and dying.........
https://www.sau.com.au/forums/topic/14531-im-odn-hard/
i know how you feel
i originally wanted a r32 and found a nice black one with gtr intercooler, bigger turbo, air filter, 3" piping exhaust, 17" mags with 255 tyres for 15k
and then i got rejected
yes its freakin depressing when you get all worked up
but luck changes, if you set yer heart on it, you will get it
tho i sometimes wish i got that 32
it was so ****in fast....
https://www.sau.com.au/forums/topic/14531-im-odn-hard/#findComment-294276
dude, go to a insurance broker, they can talk so much shit and do so many dodgies to get you a legit insurance for real chaep. Only downside is u gotta pay em like $500 or sumfin. I got mine for $2300 (rating 6, 20 yr old with 1 suspension for illegal street racing and exceeding speed limit by 118km/hr and still on my Ps) I paid the broker like $250 and he got me one thru Just Cars. Altho this IS for a R32 GTS, so I dunno.
The broker I used now lives in England or sumfin, coz I rang him to try n get quotes for insuring the R32 GTR... so I doubt he could help u, but I'm sure another would do the same thing.
https://www.sau.com.au/forums/topic/14531-im-odn-hard/#findComment-294537
I pay around $1800 under my dad (has been rating 1 for 10 + years) with me as second driver.
how the hell do you do that? i heard you can't do that with imports. my dad has rating 1 for bout 15 years but they wouldn't let me be second driver
https://www.sau.com.au/forums/topic/14531-im-odn-hard/#findComment-294899
Guest INASNT
well i am second driver on weekends or sumthing.
just under me its around 4k.
Just cars is good coz u can have as many mods as u want
https://www.sau.com.au/forums/topic/14531-im-odn-hard/#findComment-295059
dont be pissed about a vs calais
stil a nice
look at what all other p platers r driving these days
toranas geminis etc
very nice car
just wait a year and get a skyline
u can stil make these cars go..
extracotrs exahaust cam and chip and it cgoes not to bad.....
its not da end of the world.. i had a vs s pac for a good year and a half b4 i got my skyline.......
over all vs calais nice car .. is it ur first? cause if it is
**** me ... my first car was an XD.. vs calais would have been a dream.
https://www.sau.com.au/forums/topic/14531-im-odn-hard/#findComment-295103
your stuffed if you have an accident during the week then denham..
Try uniquecar.com.au but only if you are over 25.. but they will insure all mods too and full value (justcars generally just gives agreed value).
justcars is a ****ing ripoff
https://www.sau.com.au/forums/topic/14531-im-odn-hard/#findComment-295110
Guest INASNT
im 26 this year!
but got a crap rating coz i had a 4.1 litre cortina on my p's and that was p plate illegal so it was under my dads name 2!
https://www.sau.com.au/forums/topic/14531-im-odn-hard/#findComment-295157
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
