Well, theres a post in general discussion area thing about this, but thought id post up here to see if anyone is keen.
HKS will be bringing their R33 GTR out of retirement to take on the Heat Treatments R32 (now the quickest in the world) in New Zealand on the 17th Feb 2007.
Me and Aurora are going to fly over on Friday the 16th and come back on Sunday the 18th. Plane tickets are $189 each way with Air New Zealand and hotel shouldnt cost too much.
So who else is interested in coming?
https://www.sau.com.au/forums/topic/145401-lets-go-watch-the-hks-drag-gtr/
Probably not since the airfares return are $380 ($189 each way) then you need probably $50 - $100 for accomodation, entry to the drags (no idea on ticket prices, they come out in jan) and food.
Id say $650-750 and you should be pretty safe.
Also those prices are from Sydney, so if theres enough interest we can all chip in $10 and hire a mini-van for the drive up to and back from Sydney.
Come on peoples, who DOESNT want to see the two fastest skylines in the world go head to head? :happy:
Edited by Amaru
I'm officially barred up...
I'm barred up knowing that you're barred up....
I've said too much........
Anyway, it's be great fun but my money belongs elsewhere. I'll just wait for the cliff notes to come out. (read: video).
Yeah I was shocked at the ticket prices too.
And you will see the cars out multiple times during the day, not just once... and thus far, every time the HKS car has gone to an international event they dont strictly do drags with it either (those that saw it on the rained out day at willowbank will understand).
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
