Hey people,
Have got this stuff to get rid of, parts are located in Melb Eastern Suburbs, although I dont mind posting either.
If you need more info or pics of something just PM me or give me a call.
This thread is constanly having stuff added to it!
Sold and new items listed at end of thread
Ive got pics of the other items that dont have pictures up, only because they take ages to upload em all!
Prices nego.
Thanks,
Mat.
0400 558 030
Quick note:
My number is there for people who want to buy something or ask questions if you are genuinely interested. Im sick of ongoing messages and calls promising to call back and pick up parts but never show.
Dont waste my time!
Messages will not be replied to anymore; just call.
All genuine enquiries welcome.
> 3" Pod Filter Adaptor - $15
Universal adaptor to bolt to your afm, to fit 2 3/4" - 3" pods filters. Suits any afm.
> 330mm Steering Wheel - $50
Light weight, steel centre, rubber outer / handle. This will fit to any boos kit no dramas. Great condish.
> 90 Degree Dash 10 Fitting for rear head oil drain - $10
> Apexi RSM Shift Light - $20
> Racetech 5" Tacho - $30
Perfect for use with the RSM Shift light on your line. Connect the tach and hide in under your dash, wire the shift light to it. That way u dont have this gay massive tach on your dash, and u dont have to spend 150+ on a pivot shift light!
> 32 GTR Billet Steel Lightened Flywheel - $300
http://www.skylinesaustralia.com/forums/Bi...Fl-t214863.html
> 32 GTR Front Rotors - $420
Brand new in boxes, RDA Slotted and Dimpled front disc set. Cheaper than the group buy too! Ready to go..
> 33 GTSt Front Rotors - $450
> RB26 Turbo Oil / Water Supply Lines - $15ea
These are the lines that bolt onto the core of the turbo with banjo bolts, and mount onto the comp housing.
> RB26 NDC bearings - $150
Japanese bearing set, big end and main bearing sets to suit standard crank and rod specs. Brand new unused.
> RB26 N1 Pistons $100 set(6)
1mm oversize (88mm) used pistons for RB26. 3 Perfect condition, 3 with cracked ringlands. Good to get someone out of trouble...come with gudgeons.
> 32 GTR RB26 Engine Block - $300 MUST GO
Had it sitting for months now, just want it gone. Nothing wrong with it, bores are at 86.5 which are glazed, so a hone etc will be needed. Only reason for not using this block is the prior purchase of 33 virgin block used for engine swapover.
> Brand New Genuine Nissan Thermostat - $60
Suits all RB engines. In Nissan box etc. Part No: 21200-42L06
> GTR Dump Pipe Gaskets - $15ea
New Nissan Metal gaskets. Also fits any T28 turbo.
> GTR Oil Pump Gasket - $20
Genuine Nissan Item. Left over from build.
> GTR "Twin Turbo" pipe Gasket - $10
The gaskets between the turbo comp housing outlet and the twin turbo pipings.
> Z32 AFMs - $285ea
Brand new genuine Bosch. Selling as i dont need them right now, but probly even d-jetro later. Part No: 22680 30P00 A36-000 N62 7129B
> Bosch Plug kit to suit Z32 - $35
Youll need one of these if you intend to install a Z32 in your car. Part No: 1 287 013 004
> R33 GTR NTK 02 or Lambda Sensors - $90ea FIRM
02 Sensors that i was going to fit aaaages ago before i had a PFC but now with new dumps no 02s are needed anymore. These new as well of course. Will fit GTS-t too.
> Skyline CAS - $320
Genuine Mitsubishi RB Crank Angle Sensor, suits RB26 and 25 definately. Thought mine was bung but turns out its fine! NEW! Unfitted.
> Skyline / VL TPS - $100
TPS (Throttle Position Switch) for RBs. Been sitting here for ages. Needs to be gone! Suits almost all lines me thinks.
> 32 GTR D/S Engine Mount - $40 - offers
> Universal Guard Rolling Tool - $220
Brand New in box, high quality.
> 2 x 16" x 7" Impul RS Wheels - $100 ANY offers!
Ultra lightweight racing rims, tyres down to wear bars, youd get a few drifts out of them....offset 38 i think. No centre caps.
> 32 GTR Genuine Nissan Head Gasket - $80
Brand new in packaging, fits all GTRs and maybe 20s and 25s?
> 32 GTR Aircon Receiver Dryer - $30
> 32 GTSt Spoiler - $75 - ANY OFFERS!
Perfect nic, black in colour with centre led brake light.
> CA18DET 02 Sensor NTK BRAND NEW - $90
> 32 GTR HICAS System - $___
Just assorted parts. Good if something in your system is busted. Everything was working when removed.
> 32 GTR BOV Gaskets - $20 for both - offers
New Genuine Nissan metal BOV gaskets. Might fits 33 as well.
> 32 GTR stick shift housing - it bolts on the top of the gearbox - $25 - offers
> 32 GTR Brand New in boxes NTK Lambda sensors (set of 2) - $180
http://www.skylinesaustralia.com/forums/in...6&hl=lambda
> 32 33 34 GTR Brand New Aftermarket Fuel system setup - $850!!
http://www.skylinesaustralia.com/forums/in...howtopic=132293
> 32 GTSt PBR Clutch Master Cylinder (Brand New and Direct Fit) - $110
> 33 GTSt Rear Seats - $50 - ANY OFFERS!
> 32 GTSt Whiteline Swaybar Link Kit 90mm KLS090B - $100
This is the kit that you need to attach Whiteline Sway Bars to the rear suspension arms. The kit is brand new and unopened, come with all bushes etc. "Single eye link kit with hardware 90mm centres".
> 32 front windscreen moulds left and right - $30 - offers
> 32 rear wiper motor (thread broken) but would be fine to use - $10
> 32 'Skyline' bonnet liner with clips - $35 - offers
> Sandwich type wheel spacers brand new x2 5 Multistud 10mm - $15 pair
> Brand New Bosch 044 external pump - $230 Express posted
> Brand New Bosch 040 internal pump - $230 Express posted
> New Earls Fittings to suit Bosch Pump OUT side - Dash 6 - $25
Basically the two fittings you need to hook up your Bosch pump to the fuel line. Also have some other fittings lying around as well. All new, just ask and i might have what youre looking for.
> Brand New Surge tank and 044 setup - $500
http://www.skylinesaustralia.com/forums/in...howtopic=143583
> HKS Electronic Boost Guage - $50 - ANY OFFERS!
This is the guage itself only, you need the MAP sensor and wiring to get this working. Mad condition. Black face with orange numbers etc. Reads up to 2.5 bar. Good for someone with a broken, cracked or shit condition HKS guage...
Edited by Shell
  • Replies 140
Posted Images
also....wat the light globe holder?
Nope sorry, i do have some other bits n pieces not worth listing lying around but none of what you are after.
Good luck!
keen on your multi-stud spacers. is that 10mm as well? will it fit 5x100 as well as 5x114.3?how much is the postage to sydney (2170)? will likely take them if suit my application
PM sent
iv already got a 044 would you split the surge tank if so how much for it
Yes willing to separate the surge tank setup, PM sent.
Have you got the GTR32 standard exhaust?
Nope sorry, but i do have an aftermarket catback for 32 with magnaflow muffler 3" if thats any help.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
