Hi all, does anyone have experience wih either of these rust repairists?
I have seen Adrians Rust Repair sponsors on at least one car, does that mean he's good?
Adrian's Rust Repairs
206b Stubbs Tce Shenton Park 6008
(08) 9380 6620
Malaga Rust Repairs
Unit 3/ 37 -41 Pavers Crcle Malaga 6090
(08) 9248 1820
If there are any others NoR please let me know. We have none listed for NoR peeps yet.
https://www.sau.com.au/forums/topic/145477-rust-repair/
im sure most if not all pannel beaters can do it
chop it, re-weld it, anti rust it, spray it
TA DA! but most of them wont give u any warranty (except dmg control @ maddinton outta all the ones that quoted me yoinks ago for my celica)
https://www.sau.com.au/forums/topic/145477-rust-repair/#findComment-2720622
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
